Hot battery ...... no power! - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2011, 04:52 PM
muzzfactor's Avatar
Hey guys, I finally got around to starting my '79 Trans Am today and when I tried.....nothing! Had the battery checked and its okay, but Im not getting any juice anywhere else, the lights won't even come on. Am I missing something here? I did have the steering column and fuse box out, but thought I put everything back correctly is there something that I should check? Thanks again.
Old 07-17-2011, 06:54 PM
mud.man.rj's Avatar
Start checking for power from the battery terminals and work your way back slowly, maybe blew a fuseable link from battery to fuse box, would explain no lights.
Old 07-17-2011, 07:21 PM
bubbahotep's Avatar
How good is the ground connection? Thats as important as the positive side.
Might be a burnt wire from the starter to the rest of the car if thats where the connection for +12v is.
At least check that with everything OFF, you have 12v down at the starter. Check from chasis to the big fat red wire coming from the battery. Then go from there
Old 07-17-2011, 07:48 PM
muzzfactor's Avatar
ok guys, im a complete idiot!! I thought the fuse box only mounted one way, I was wrong, turned it 180 degrees and i'm back in business. Sorry for my ignorance!
Old 07-18-2011, 09:12 AM
PATH=$PATH\:/usr/local/bin ; e
LOL I bet you aren't the only one to have done something like that... Just one of those humbling little life's lessons.. Glad you found it.
No battery power after starter replaced Rosewood Electrical 7 07-02-2010 10:02 PM
Suggestions for battery tray/box for a group 75 battery grobb284 Electrical 1 10-05-2009 10:28 PM
Can a low low battery, cause car to bog? Rubberman2003 Electrical 17 08-31-2003 08:19 PM
Is it the battery or......? Teal96TA Electrical 4 11-16-2002 06:28 PM
anyone know anything about putting power brakes and power steering on a '63 impala SS Benni520 Suspension - Brakes - Steering 0 10-14-2002 01:22 PM
