hot coil
the coil is getting hot on a 318 dodge and won't run when hot thanks for the help
Doc here, Lot's of good info to go on there.... Do you have the ballast connected? Is the Tac connected? Internal Ballast loaded or External Ballast loaded? Oil filled or Air Cooled windings? Is the IGN wire somehow bypassed? What was the primary resistance in OHMS? Coils GET hot doing their work..are you sure it is not normal? you can burn your hand on some if your not careful.. Is the module properly installed? How much Silicone was used? What Coil are you using? Stock or performance? What gauge wire is feeding the Coil + terminal? Doc
Aftermarket Solutions Electronic & Electrical Innovations |
| Hot ignition coil | 48 Keystone Koupe | Electrical | 4 | 07-13-2007 10:44 AM |
| Hello Hot Rod Fans | acedrummer | Introduce Yourself | 5 | 07-17-2006 10:54 PM |
| 2 new forums: Hot Rod Art and Off-Topic | Jon | Hotrodders' Lounge | 2 | 09-23-2005 03:50 PM |
| capicator for coil?? points ignition HELP | jadye | Electrical | 2 | 04-30-2004 10:17 AM |
| Hot Rod of the Week suggestions? | Jon | Hotrodders' Lounge | 30 | 06-02-2003 04:53 AM |
