Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hot engine start issue
Old 07-11-2012, 06:46 PM
EOD Guy's Avatar
EOD Guy EOD Guy is offline
possible frayed/broken wire from the ing switch, could be engine bay side or the firewall connectior or cabin area....... cabin side ..... make sure no one has tapped into that wire to run something else or it has a solid connection to the switch terminal........ firewall connector...... corrosion or broken connection at the bulkhead connector....... engine bay ..... wire broken/frayed or it could be brittle from lying on the engine etc.....
Good luck
