Hot engine start issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2012, 06:51 PM
I have a custom 49 chevy PU with a chevy 383 HEI ignition. Engine starts fine and runs great. Turn off and after 5 minutes of a hot engine and try to start I get no spark to plugs. I replaced the coil, ignition module, wires, cap, rotor. Still no spark. Finally ut in new distributed, still have same problem. I'm lost!! Any help would be appreciated
Old 07-10-2012, 07:25 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Do you have 12 volts going to the distributor?
Is the distributor grounded to the block? The clamp is the ground path so make sure that the clamp ring is clean (no paint).
How are you testing for spark?
Run a jumper direct from the battery to the distributor to eliminate the wiring and ignition sw.
vicrod
Old 07-11-2012, 03:43 AM
EOD Guy's Avatar
X2 with Vic's questions.
Old 07-11-2012, 04:10 PM
Thanks for the reply. I really appreciate it! Have not checked, but will. If the direct line to distributer from battery works, than what might be the problem? A short in the line? Could there be an issue in the ignition switch? Thanks again!
Old 07-11-2012, 05:46 PM
EOD Guy's Avatar
possible frayed/broken wire from the ing switch, could be engine bay side or the firewall connectior or cabin area....... cabin side ..... make sure no one has tapped into that wire to run something else or it has a solid connection to the switch terminal........ firewall connector...... corrosion or broken connection at the bulkhead connector....... engine bay ..... wire broken/frayed or it could be brittle from lying on the engine etc.....
Good luck
Old 07-11-2012, 06:28 PM
T-bucket23's Avatar
Wiki Edits: 26
The jumper will eliminate everything in the ignition wiring. If it starts then trouble shoot it back from there.
Please stop replacing parts until you are sure they are bad.
Chet
Old 07-13-2012, 07:38 AM
Joe23
Ok, i thought I wasn't getting spark, but I am. When the no start occurs, the initial ignition sound like the battery is weak to the starter. And then it just turns over with no fire? I replaced the battery and same problem when it is hot?????
Old 07-13-2012, 10:49 AM
Joe23
Could it be in the timing or ground straps for battery. The battery sits in the bed of the truck. I've set the timing at between 10-12 BTDC. When cold starts fine and runs smooth. Again this is a 49 custom Chevy with a 383 cu in engine. This starting issue is driving me crazy! Recap of what's been done.
New fuel pump. Re-route of fuel lines away from heat. New distributer. New battery. All new guts to distributed. I am getting spark when this no start on hot engine occurs.?????
FAST EZ EFI hot start issue redride Engine 9 05-29-2012 06:49 AM
Best 60s Issue of Hot Rod Magazine and best 50s Issue of Car Craft MXrider13 Hotrodders' Lounge 18 07-29-2011 01:55 PM
Hot start issue redride Engine 14 08-13-2010 10:55 AM
engine start fine when cold when HOT I have to wait about 1/2 hour amature Engine 15 09-05-2009 07:25 AM
Hot start issue e6205m Engine 6 09-05-2008 02:57 PM
