Hot Floors - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2011, 06:17 PM
Buckeye Bob's Avatar
Hot Floors
I HAVE A 53 MERCURY CONVERTIBLE WITH A 5.0 & A O D
THE FLOORS IN MY CAR GET SO HOT THAT MY WIFE HAS TO PICK UP HER FEET.I DONT KNOW WHAT TO DO,SOMEONE TOLD ME TO WRAP
THE EXHAUST,I DID & STILL NO HELP,I HAD A HEAT SHIELD PUT
OVER EACH MUFFLER & STILL NO HELP.I WAS TOLD TO TAKE THE WRAP
OFF & USE 2/12 in EXHAUST.I REALLY NEED SOME HELP.THANKS BOB
Old 09-18-2011, 06:34 PM
cool rockin daddy's Avatar
Move the exhaust away from floors or put dynamat on the floors. Check your timing and your valve lash and make sure you are not burning unspent fuel in your exhaust.
Old 09-18-2011, 09:14 PM
DoubleVision's Avatar
What Cool Rockin` said. Also check for a very lean fuel mixture. I used to have a camaro that did this same thing. It had a warped intake so it had a vacuum leak that was causing it to run lean. The floor got so hot by the time I got out of it my socks and shoes were soaked in sweat. Worst part about that was it was also causing the master cylinder to get so hot it was boiling out the brake fluid. I chased that problem for months before I figured out the intake was warped.
Old 09-19-2011, 05:41 PM
11echo's Avatar
Old Guys Rule!...EVERYTHING!
I had this problem on my vette, the heat sheild and insulation were missing. Once I got that back on, had no problems.
Old 09-19-2011, 06:45 PM
Irelands child's Avatar
Summit sells Flowmaster heat shields here
This is what they look like on my car, not that you can see much:
They do work.
Dave W
Irelands child
Sub floors in rod projects stitcher_guy Interior 7 11-09-2007 02:17 PM
Floors for the 66 Elky Bryan59EC Hotrodders' Lounge 3 10-03-2007 06:58 PM
Welding floors????? Nightfire Hotrodding Basics 10 01-28-2007 08:43 PM
Shop floors gr8art Hotrodding Basics 7 09-21-2006 11:07 AM
Poncho Floors? DragLinkscc Hotrodders' Lounge 21 08-26-2002 05:30 PM
