Hot headers - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2002, 04:03 PM
Post Hot headers
WE are experiencing hot glowing headers in a short time when firing up a fresh 455 Olds.
Could this mean our timing is off?
Any other info would be helpful.
Old 02-09-2002, 12:25 AM
Wink
Does the engine have a radical cam and Big cfm carb? Sounds like maybe it has excessive rich condition with too much timing. Holley carb ? If so, the power valve may be open all the time. Single plane manifolds may cause fuel puddling. Need a little more info on your engine component combination to make a informed diagnosis.
Old 02-10-2002, 06:20 PM
Post
I would look at the carb.obviously the timing must be close enough that it will start and stay running,but It sounds to me like you may be running it lean. This will make your headers turn colour in a hurry, not to mention the havoc it could be doing to your engine. Dont run it to long until you verify your timing and your carb sizing.
Old 02-11-2002, 10:27 AM
New Member
Cool
I had a simalar problem on a big block with high
compression and the problem wound up being too lean,a new Demon took care of it and it runs great
now.
Old 02-11-2002, 11:28 AM
Cool
The problem is the engine is running way to lean. If This condition is not corrected you will damage a lot of expensive parts. I had a motorcycle once that someone had set up too lean and it did the same thing. Actualy ruined the chrome on the pipes.
Old 02-12-2002, 11:40 AM
F-1Rodder's Avatar
Post
You have a too lean condition. Actually, an overly rich engine runs cooler, not hotter. You also may be a little too far advanced as well.
Old 02-12-2002, 02:56 PM
Post
retarded timing can and will cause red hot exhaust-I recommend referring to some sort of service manual to get an idea of the baseline timing required for your engine. If I remember right, olds motors do take quite a bit. You can also get a relative idea of rich/lean, by introducing fuel or extra air when running it in the stall by using propane, carb spray, or opening the pcv valve hose.
Old 02-24-2002, 07:22 PM
Post
is the engine tep ok? Beacuse i had a big block pontiac that had a water prot closed that caused the headers to glow orange. hope this helps
