Hot Hues help!! Paint problems. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-12-2012, 06:20 PM
My 40 Chev coupe is painted with Hot Hues cosmic dust. I have made repairs before and not had a problem blending, but now I can't seem to get the metallic to stand out like before. In the sun the original paint just pops with metal. The new is like regular metallic. I'm not a painter so I'm not sure if my paint is wrong or am I spraying to close, to far. Mixed to thin, to thick. It is a new quart but Ive bought it before and it matched perfect. Any ideas. All help would be appreciated.
Name:	hot rod web pic.jpg
ID:	61784   Click image for larger version
Name:	hot rod web pic 2.jpg
Old 01-13-2012, 10:15 AM
Really? No Painter tips?
I could really use some help here if anyone has a suggestion.
Old 01-18-2012, 05:26 AM
deadbodyman's Avatar
Wiki Edits: 11
You could try a faster reducer.its colger out now so what you used in the warmer weather will dry slower allowing the metallics to lay down if your not very carefull....holding the gun farther away is another thing you can do of *** a couple coats on before you clear...
Old 01-18-2012, 07:22 AM
delawarebill's Avatar
paint...
u just may need to call DuPont in wilm delaware for a better answer.... i had a problem 30 yrs ago with there wax.. not commng off and they sent me a case of stuff to remove it if needed.. very helpfull.. don't know the # off hand of course u can google it...
Old 01-18-2012, 10:05 AM
Thanks for the info. I started thinking temperature might have something to do with it. I also remembered I let the car sit a day before clearing it the first time. I will wait for warmer weather and try again.
Old 01-18-2012, 11:09 AM
Wiki Edits: 11
OR FOG a couple coats on before you clear....
I dont know what I spelled this morning but it must have been bad
Old 01-18-2012, 12:26 PM
cyclopsblown34's Avatar
Colorsanding painter
you musta typed something Funky. oops.
Old 01-18-2012, 01:33 PM
I think I will try a new gun also. Same tip though. 1.4
Old 01-19-2012, 05:56 AM
Wiki Edits: 11
I've always used a 1.4 for my base AND clear but I recently got a deal on a Sata with a 1.3 tip and I couldnt believe the difference in the amount of base it saved me ,I was wasting a lot of base it also works great for lower end SS paints like Nason...I still use the 1.4 but only for my clears...
Old 01-19-2012, 07:55 AM
My NR95 has a 1.3 tip and is my base gun. I tried using my 3000RP 1.4 tip with base and it made a monster cloud. I also have a SATAJET RP I use for clear along with the 3000RP depending on my mood. The two of them make the clear lay like glass...even cheap clear if I don't have my SPI ordered in time.
Painting with Dupont Hot Hues Paint larself Body - Exterior 3 03-04-2011 06:33 PM
Dupont Hot Hues Supplier in Orlando? mverta Body - Exterior 0 05-28-2009 06:37 AM
Dupont Hot Hues MIKE FROM SM Body - Exterior 6 02-17-2007 10:11 AM
Paint color question (hot hues)? fatnlow Body - Exterior 3 02-28-2006 12:40 PM
Paint Problems buckred Body - Exterior 3 03-27-2005 07:08 PM
