sounds pretty interesting.
Have you actually used it??? I was wondering how the lead would stick to the metal if the metal wasnt heated to the proper temp...Kinda like dripping hot lead on the car ,it just sits there,not really stuck on good...
The Non lead will he heated up to a liquid and then sprayed on , soon as it hit the colder metal it will burn into the pre tinned area and cool down, no drips.
You have to apply thin layers , Runs will only appear when you spray to long on one area The lead than has not the time to release its heat and will create a puddle that will run down. same as paint if you put a too heavy coat on it will run. |
Ok, I got it now... pre tinned (treated,heated and lightly coated with lead or leadless) the hot lead melts into a leaded surface...it DOES sound cool...Ok ,so now ,whats a 52 fiper ????
WHOOOOO,That is awsome.I'm glad I asked..
Thats really nice.. |
Years ago a fellow came by the shop and demonstrated a gun that sprayed aluminum. It had a grinder that ground aluminum wire into a dust and sprayed it across a flame and onto the surface. It attached to a standard oxy/acetylene torch and used shop air. And it worked! It stuck good to well prepped metal. Didn't have enough money to buy it and haven't seen one sense.
Russ |
Lead Spray Gun.
Gentlemen; about the posting of the lead spray gun. There were several companied that made them. I have two at the present time. One is a Brents and off hand I cannot remember the other. To use the Brents lead gun you had two connections. One to an air compressor and rubber hose connected to the acetylene-oxygen tanks. Lead sticks were feed into a small box in the front part of the gun were a flame melt the lead. The metal to be lead was sandblasted or taken down to bare metal, the wiped with a tinning solution that changed the bare metal to a copper look. Then comes a dangerous step but can be performed with care. Steel wool was dipped into mercury and wiped on the area to be leaded. This tinned the metal. I use a long handled pliers to hold the steel wool while dipping into the mercury and wipping on the metal. After this the lead was spraied on the metal until the desired thickness of lead was built-up.
If any of you out ther have any printed info on these lead guns Please pass them on. |
| Why is is bad to spray primer through a exspensive gun? | hutcholdschool | Body - Exterior | 12 | 01-31-2009 09:19 AM |
| Not Another Spray Gun Question! | Workingwoods | Body - Exterior | 11 | 07-17-2008 02:07 PM |
| low priced spray gun/detail gun for primer/base/clear and ghost flames | jrmy_1 | Body - Exterior | 15 | 06-08-2008 06:38 AM |
| mini spray gun porter cable | quack | Body - Exterior | 5 | 04-19-2006 08:47 AM |
| Need a good spray gun for spraying metallic base | camaro freak | Body - Exterior | 1 | 04-18-2006 05:26 AM |
