hot motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2012, 11:42 AM
hot motor
I have a 1968 350 vette motor in a 1933 chevy. The car starts fine with an electric fuel pump and pump the accel twice. My problem is when I stop after running it for 3 to 4 miles and stop it, it does not want start back up. I thought the battery was weak put a new one in and did not help. When I fire it up its like a vapor lock. Could the timing be off. It is a double pumper Holley
Old 09-11-2012, 11:46 AM
vinniekq2's Avatar
Do you pump the carb when you restart? does the carb perk after you shut it off?Does the engine turn over quickly or really slow?when hot
Old 09-11-2012, 11:54 AM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Sounds more like you have 'heat soak' of the starter/solenoid. Do you have a heat shield over the solenoid? headers close to starter? Good grounding? ground wire from frame to body to engine?
You could go for putting a Ford solenoid on the side skirt of the fender like Madd enterprises does. http://www.madelectrical.com/catalog/st-1.shtml or this one: http://www.chevelles.com/forums/show...highlight=ford
http://novaresource.org/starter.htm
Note. 68 Corvettes were a 327, not a 350.
Old 09-11-2012, 02:57 PM
spinn's Avatar
Wont crank. turns over fast but wont fire. Not being specific. Please be verbose in your problem . No mind readers here.
16+ initial timing will give you hot start crank problems. Most driven vehicles that are cammed like 20 initial, but will crank slow when hot. Fix is a starter retard device, or vacuum advance added from manifold source at idle to compensate.
Starter will not turn after motor gets hot Bracewell Engine 5 05-15-2011 07:11 AM
Custom motor mounts for my hot rod unique Engine 3 05-14-2008 09:05 PM
Hot Rods September Cover Motor malc Hotrodders' Lounge 3 08-09-2006 09:01 AM
I have narrowed it down to which motor i'm going to run in my hot rod mercflathead Engine 10 04-09-2005 08:53 AM
building a hot motor mgm Hotrodders' Lounge 4 03-14-2003 08:15 PM
