Hot MSD Coil - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2006, 09:39 PM
97Z28's Avatar
NTI Grad.
Hot MSD Coil
i just installed an MSD blaster 2 coil and MSD wires on an 86 dodge W-250 4x4 with a 5.9L (360) engine. i was just wondering why the coil was heating up to the point where you almost cant touch it. is that normal? or did i cross wires somewhere? it starts up and runs fine the coil just gets hot. plus i installed a new ballast resistor. thanks for the help in advance guys....
Old 07-30-2006, 12:51 AM
97Z28's Avatar
NTI Grad.
anybody? ????
Old 07-30-2006, 03:23 PM
johnsongrass1's Avatar
Race it, Don't rice it!
They do heat quite much. Every one I've had does.
Old 07-30-2006, 04:42 PM
97Z28's Avatar
NTI Grad.
ok cool. i've never really felt a coil after a cars been running so i dont know. one other thing... i left off the radio noise capacitor.... what effects will that have?
Old 07-30-2006, 07:22 PM
larryblack's Avatar
Certified Lead Foot
More radio noise AKA buzzing, and not much else.
Old 07-30-2006, 07:59 PM
97Z28's Avatar
NTI Grad.
ok cool... thanks
Old 07-30-2006, 08:12 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Hot enough that you almost can't touch it...?????? How hot is that? 135*?
That is not hot.
Underhood temps run above 200* in many cars. Upwards of 240* idling in city traffic.
www.readershotrods.com
Old 07-30-2006, 08:49 PM
97Z28's Avatar
NTI Grad.
well... the stock coil didnt get near as hot as this MSD is getting
Old 07-30-2006, 09:07 PM
xntrik's Avatar
No problem... I know you are running it for a while with the hood up, but if you can touch it, it isn't too hot. They are designed for extreme use.
If you had an MSD-6 box on it (sparking about 8 times each cylinder instead of one),,,,, then it would really be hot..... yehaw.
Old 07-30-2006, 10:02 PM
97Z28's Avatar
NTI Grad.
ok cool.... thanks man. i was just making sure it wasnt shorted out or something. thanks for the help!
Old 07-30-2006, 10:59 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
The Coil will run warm..Consider it is sinking about 20 to 40 amps to ground each time the trigger pulse goes low..
You MIGHT want to check to see if a Ballast resistor is required on the primary of the MSD coil for your application. If it is, and you don't have one, the coil will die a premature death...
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 07-31-2006, 05:34 AM
97Z28's Avatar
NTI Grad.
yeah. it does require a resistor, and MSD gave me a new one so i replaced the old one with the new one just to be safe. Thanks Doc
hot Coil street rodder 1937 Electrical 2 04-26-2005 09:32 PM
MSD offroad-6, MSD 8366 Distributor, Holley 950 ECU izord Electrical 0 09-06-2004 02:16 PM
HELP NEEDED Coil very hot Moby302 Electrical 6 01-05-2004 04:15 PM
No Spark at Coil/ 350 SBC 1966impala Electrical 4 10-01-2003 12:07 PM
Hot Rod of the Week suggestions? Jon Hotrodders' Lounge 30 06-02-2003 04:53 AM
