hot power steering pump, - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2008, 03:13 PM
steve t's Avatar
ex biker, now hotrodder
i installed new power steering pump on 61 impala,new p s system,ram and valve.pump runs real hot in no time ,when you start engine,idle like 1 min, what is wrong, help
Old 09-28-2008, 04:06 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Do you have Headers on it, and how close is the exhaust routed to it?
Old 09-28-2008, 04:45 PM
steve t's Avatar
thanks, but it not the headers
Old 09-28-2008, 06:32 PM
My 2 cents worth
Wiki Edits: 3
OK, You say it get's 'hot after 1 minute of running'. Does the fluid get 'foamy'? Making you think it gets hot, or is it too hot to touch?
What "type" of steering system do you have? I take it, that you have a 'pump, and rack' assembly. What is it out of?
Does it have a pump, control valve, and power cylinder? Early GM, and Ford passenger cars used this system. These systems are also easy to adapt into other older cars. Been there, and done that.
This could be as 'simple' as the P/S pump pulley spinning backwards, or a defective pump.
Old 10-07-2008, 05:36 PM
steve t's Avatar
i fixed the problem, it was a air lock in system,bleed it out
1971 chevy 350 power steering pump colincamaro Suspension - Brakes - Steering 10 12-27-2006 01:14 AM
Pully problems: sbc 671 weiand, power steering malibu68 Engine 1 12-05-2006 10:09 AM
1989 Silverado Power Steering Pump Canadian Charlie Suspension - Brakes - Steering 3 05-16-2006 01:28 PM
power steering from long water pump to short water pump kellyem Suspension - Brakes - Steering 7 02-22-2004 07:22 PM
power steering pump impala dreaming Suspension - Brakes - Steering 3 02-15-2003 05:00 PM
