hot rod black primer - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2008, 03:15 PM
im going to paint 68 camaro using chromabase bc/cc. im painting it the same color which is glacier blue. can i just sand the clear, clean and just shoot the new paint or do i have to prime it? if priming is necessary, ive got #5401 HOT ROD BLACK-ACRYLIC LACQUER PRIMER SURFACER. my question is is this compatable with chromabase? also will it make a big difference weather i use black primer or grey primer, as far as color is concerened? thanks in advanced
Old 05-22-2008, 05:02 PM
I think that I read somewhere that Glacier Blue (thats the light factory blue right?) had grey primer from the factory, It may be slightly darker with black primer.
Shane
Old 05-22-2008, 05:17 PM
yes it is the blue factory color. how much darker do you think it will come out.
Old 05-22-2008, 09:28 PM
I wouldn't use the laquer primer for anything. I would use a urethane primer in grey or buff color. You can check with the people that mix your paint and they will tell you the value shade of the paint and get the right colored primer to go with your paint. All the dupont reps. and expierenced painters/body men I have talked all say the same thing about the laquer based primers, they don't bond well with the paint and your paint job is only as strong as the weakest link, so if the primer doesn't bond well then your paint can chip off.
Hot rod builders wanted- Western N.C. WoodsEdge Hotrodders' Lounge 16 11-13-2013 01:47 PM
Beverly Hillbillies Hot Rod tgotcha Hotrodders' Lounge 19 05-09-2013 09:50 PM
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 03:07 AM
HOT ROD vs Car Craft magazine FASTCHEVY Hotrodders' Lounge 35 03-25-2008 04:11 PM
