hot rod model a rear end
HI JUST BOUGHT A NEW AFTER MARKET MODEL A FRAME..IT HAS A 32 FRONT CROSS MEMBER AND RAISED 3 INCHES IN THE REAR.
I AM USING A 31 SEDAN BODY. COULD SOME ONE TELL ME WHAT TYPE OF REAR END I SHOULD PUT IN IT? WHAT I AM LOOKIN FOR IS HOW WIDE IT SHOULD BE.. (OUT SIDE TO OUT SIDE) I AM NOT GOING TO RUN FENDERS. BUT IT WILL BE A HIGH BOY STYLE. I HAVE A 70 NOVA REAR END AND A S10 4X4 REAR END WILL ONE OF THESE WORK? IF NOT WHAT SHOULD I LOOK FOR?????? THANKS FOR YOUR HELP...
Most Model A guys like to run a Ford rear end......either a 8 inch series or the stronger 9 inch. I prefer the 9 inch myself. 1957 to 1959 Ford cars have a 9 inch series rear end that is 58 inch....measured the way you described.....
The 9 inch is " The choice " of most rodders because of the strength and the ease of changing gears. The parts availability is GREAT Also... I have a early Ford Bronco 9 inch series rear en under my 32 Ford roadster....it is 58 inches also but has the 5 on 5.5 wheel pattern.......which I wanted.....to match my 56 F-100 front brakes... On my 32 3W........under construction..I used a 57 Ford 9 inch...with the big axle bearings.....look at my project journal for a few " under construction photos " The 70 Nova rear should measure out at 60 inches....and the S-10 4x4 rear end is most likely too narrow. I do not like either......because of the way the gear is installed.....and the axle bearings are in the tubes.....not on the axle shafts....but that is just me......
| 383 vs 350 | TheCiscoKid | Engine | 86 | 05-03-2008 03:10 PM |
| rear end for a model a | wayne robertson | General Rodding Tech | 5 | 03-17-2006 06:23 PM |
| model a rear end | wayne robertson | Hotrodders Site Suggestions and Help | 1 | 03-17-2006 09:07 AM |
| S-10/Camaro Rear End | slaveforthewave | Transmission - Rearend | 7 | 02-20-2006 01:44 PM |
| 327 in 88 Truck | pete379 | Engine | 101 | 01-19-2006 09:03 PM |
