Hot rod rear end gears - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2007, 07:51 AM
47chevrolet's Avatar
BuRnIn RuBbEr
Last journal entry: 350
What is a good torque and speed gear for a gm 10 bolt????
Old 01-16-2007, 08:02 AM
Rear Ratio
What transmission are you going to use?
Heartbeat
Old 01-16-2007, 04:19 PM
The Maintenance Geek
And what sized tires, as well...
K
Old 01-16-2007, 04:20 PM
steve t's Avatar
ex biker, now hotrodder
373,or410
Old 01-16-2007, 05:56 PM
BuRnIn RuBbEr
Tranny and tires
th-350
and 14 inch wheels with
P225/70R14 bf goodrich
i don't want to tub it out i just wat it normal
Old 01-16-2007, 11:18 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
3.42 or 3.55
Old 01-17-2007, 02:17 AM
dawg's Avatar
NAVY VETERAN
3:50 max with 14" tires
Old 01-17-2007, 05:58 AM
elvis 66 chevelle's Avatar
66 Chevelle 406 SBC
hot rod rear end gears
i would use a 3:55 gear. i had a 57 chevy with 4:11 gears and 14 tires and a four speed. first gear would barely get you through a light.
Doug 66 chevelle 406 SBC
Old 01-17-2007, 11:23 AM
rear ratio
I have a 350cu.in./350 turbo and what I believe to be a Power Glide rear end with a 3.36 ratio in my 56 Chev and use 15" 245/70 series rear tires. I have no trouble cruising 70-80 mph, but I still feel I need another gear.
With a 10 bolt, I agree with not using anything higher than a 3.42.
Heartbeat
Old 01-17-2007, 12:24 PM
xntrik's Avatar
Heartbeat
I conclude that you said that you need another "cruise ?" gear with your 336, why would you recommend his using a 342 or more ?
Old 01-17-2007, 12:29 PM
Last journal entry: Catfish's 79 Monza Project
i think he means numerically higher.
Old 01-17-2007, 12:43 PM
xntrik's Avatar
I start out in low gear and finally shift to high gear for cruising. I think I have a Lincoln and a GM that have L for first gear on the selector.
For at least 6 decades low gear in a car makes more rpm, high gear in a car makes less rpm.
When I was a child, the "old" people were using this terminology.
Old 01-17-2007, 12:55 PM
xntrik's Avatar
I don't think that we should call first gear in a transmission high gear because it gives us high rpm, and 5th gear in a transmission low gear because it gives us low rpm.
I vote to keep it the way it has always been.
And by the way..... I vote against hot rodders and hotrod writers using the verb "install" as a noun. The noun form is "installation".
e.g. "The install was easy."
Old 01-17-2007, 01:39 PM
rear ratio
I appologize for the confusion. I'll attempt to clarify.
Yes, I mean I would not use anything numerically higher than a 3.42.
When I said in driving my 3.36 I felt that I needed another gear, that gear would be an OD in the transmission. In other words the turbo 350 and the 3.36 ratio were ok for the road, but would be better if I had a 700R4. I would still like to lower my highway RPM's.
Thanks for the comments.
Also, I agree with the installation (n) comment.
Heartbeat
Old 01-17-2007, 05:19 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
3.08 gears
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Change 4.11 to 3.08 rear end gears cares Transmission - Rearend 4 08-13-2006 01:46 PM
hot rod model a rear end longroof Transmission - Rearend 2 04-15-2006 06:47 PM
65 corvette rear end gears Kerry Picken Transmission - Rearend 1 06-03-2003 07:16 AM
Changing rear end gears... chevyelc81 Transmission - Rearend 1 07-23-2002 07:52 PM
