'Hot rodding' my garden tractor - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2014, 07:06 PM
Wiki Edits: 31
In 1968, a Sears Suburban 12 garden tractor cost $995. They didn't have hydraulics, a hydrostatic transaxle was a very rare option. They ran a belt drive and they were not really meant to be a top of the line tractor.. However, they are very simple and very tough. They rated them to take many 3pt attachments, snowblowers, dirt blades various mowers and even a front end loader.
I happen to own one of them and have for a few years. A nice untouched original that was used as a grass cutter in my town for 40 years till the guy who bought it new, passed away and his son sold it to me.. It was my backup mower but now I have another backup mower, and I have a need for a pretty heavy duty machine to do some much needed landscaping. Front end loader 3PH, box blade ect... The Sears is all I got tough enough to do the job and buying something set up to do what I want is a crap shoot for a reasonable price, and new would cost $12k
The Sears is getting
1. Fabricated Cat 0 3 point hitch, hydraulic lift and down pressure
2. Pin on/ quick hitch Front End Loader designed after rare OEM Sears loader
3. Full intergrated hydraulic system using 3 spool hydraulic valves and levers from a JD 420/430 garden tractor to provide an integrated look
4. Full hydraulic power steering using the orbital valve from a 3k series Cub Cadet since JD's use an intergrated column with their PS systems
5. 6 GPM onboard hydraulic pump that will fit in a very tight spot and be so hidden it will look factory.. Hydraulic oil tank is going to be hidden under the tractor
6. Aux hyd ports front and rear
7. Larger rear wheels with Agricultural tires
I know, not really a 'hotrod'. It tops out at 6 MPH in high gear, but the FEL, and lifting capabilities of the 3PH will come in handy when it comes to moving around heavy parts
What it looks like now..
Adding a little from
This ( hydraulic control )
This ( Orbital Steering valve )
Old 07-06-2014, 07:19 PM
poncho62's Avatar
Wiki Edits: 5
Good looking machimes Matt...I have seen you on a couple of the tractor forums...I am more into the Ford (Jacobsen) garden tractors....I like them rusty and well used....lol
Name:	015 (Small).JPG
ID:	159481   Click image for larger version
Name:	Xmas 09 075 (Medium).jpg
Old 07-06-2014, 07:44 PM
Wiki Edits: 31
Yea, you turned me to MTF when I first got this thing.. I nearly bought a Ford LTG 165 ( IIRC ) with a tiller a couple years ago, but it went too rich for my blood
Old 07-06-2014, 07:49 PM
I think you will find several of us who will enjoy your build.
I still use and enjoy my old '77 model JD 212. The old girl just won't die.
John
Old 07-06-2014, 07:57 PM
Wiki Edits: 31
That's got a K301 Kohler right? I've come pretty close to buying a 200 series a time or 2.. My grass cutters are both LX188's which are basically the later 200 series from the 90's with a lawn tractor transaxle. They have the liquid cooled Kawasaki FD501V 17hp
Old 07-06-2014, 08:29 PM
You are correct. I have had this same basic motor in this tractor and a '74 Cub Cadet. They are old workhorses for sure and parts are still plentiful. I replaced the piston, pin, and rod in this one, lapped the valves a couple of years ago and she is new again.
The Deere has a granny gear designed for a rear mounted tiller. I believe it would move the house if it could get traction.
John
Old 07-06-2014, 09:23 PM
Wiki Edits: 31
Same with the Sears. If I drop it in 1/low it moves at .75 MPH but it will pull anything.. It has a 3spd with a 2 speed differential for hi and low gears
Old 07-06-2014, 09:31 PM
It will be fun to play with for sure.
John
Old 07-07-2014, 07:02 AM
delawarebill's Avatar
pump and valving
see if u can locate a log splitter that has a bad engine, has the pump u need and valving. i've seen small hyd pistons on c/l a few times.
Old 07-07-2014, 08:27 AM
Wiki Edits: 31
Log splitter pumps are 2 stage and won't work.. They flow about 10 gpm at 500 PSI, but cut down to about 1 gpm at 1,000 PSI.. They do that for the quick returning cylinder.. This would make the hydraulics unmanageably fast unloaded and painfully slow when loaded.. Wish it would work since those pumps are everywhere
Old 07-07-2014, 08:42 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
Not sure how you are going to drive your Pump ( or,if you have a specific Pump in mind), but if you want to run a bigger pump and don't need the volume/pressure, you could use an orifice-(we use them in big Tractors sometimes)-a common orifice is used in the John Deere 835 moldboard Plow)-
If it's not in Continuous duty (used in a circuit) you shouldn't have a problem-
Old 07-07-2014, 08:46 AM
35WINDOW's Avatar
btw, wasn't your Sears built by Simplicity?
Old 07-07-2014, 09:56 AM
Wiki Edits: 31
I was looking at using this little pump Concentric/Haldex High Pressure Hydraulic Gear Pump .388 Cu. In., Model# G1224C3A300N00 | Hydraulic Pumps| Northern Tool + Equipment.. The loader requires about 6 GPM so it should be adaquate. I measured several times to make sure that it will fit where I want it and according to the dimensions in the manual, it will fit with a tiny bit of room to spare... I'm looking at 1,500 PSI operating pressure..
The Sears was built by Roper which in modern day is Husquvarna.. Early Montgomery Ward Garden Marks were Simplicity built
Old 07-07-2014, 06:39 PM
KVP's Avatar
KVP KVP is offline
I'm looking forward to the build. I have an Allis Chalmers 919 garden tractor with a twin cylinder Kohler motor as well as a Simplicity mowing tractor. These old heavy duty garden tractors will do a lot of work with the right attachments. I'm eager to see your fabrication work. BTW, I also belong to the MTF.
Old 07-07-2014, 08:09 PM
Wiki Edits: 31
I have most of a Simplicity/ Deutz Allis 914H. I bought it on ebay to get going but the disassembled engine it had turned into be a mismatched Briggs and the tractor was a basket case. I torched it in half for storage size, scrapped some of it but I still have the complete rear/ hydro and wheels.
Hot Rod Tractor! 64SS327 Hotrodders' Lounge 1 10-15-2013 09:17 PM
Ideas on adding a turbo to a garden tractor? HevDawg Hotrodding Basics 4 03-25-2009 04:53 PM
New to hot rodding rkavulla Introduce Yourself 1 07-16-2007 05:14 PM
New at Hot Rodding william sanders Introduce Yourself 1 06-24-2007 08:06 AM
Anyone know much about a John Deere 111 garden tractor? 52Caddy Hotrodders' Lounge 5 06-14-2004 07:16 PM
