hot running 350 ( literally) - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-30-2010, 08:36 PM
New Member
you might have to change you coolant temperature.
__________________________________________________ __________
Last edited by 68NovaSS; 01-16-2012 at 01:42 PM. Reason: Advertising. Please see: commercial posting guidelines.
  #17 (permalink)
Old 08-31-2010, 07:53 PM
Originally Posted by rockbatty
help an old dude out. guys I'm 56 an built my share of sbc's but have never experienced a cooling problem such as this one. it's a 9.50 to one 350, .465 lift hyd, team G intake, 650 holley; cam installed at 3 degree advance new MSD street fire HEI with all timing dead on the money with manifold vacuum advance; 3800 stall converter W/remote cooler, turbo 400, to narrowed 9" running 3;50 street gears. has largest alum Jegs radiator that will fit, w/shroud & big elect. fan, flowkooler pump, stewart high flow 160 degree therm w/bypass holes running no heater hoses but do have intake port to pump port hooked together w/molded hose, all other hoses new w/wire inserts, my first experience running alum heads, they are pro lightening heads W/felpro gaskets. car runs extremely well, but after only a short cruise runs at 205 degree w/sensor in the head, also have tryed different gauges.
I'm a bit perplexed,,, any ideas out there, any suggestions appreciated and thanks for reading this long *** thread.
I would find 205 against a 160 thermostat to be more temp than I'd expect.
Most cooling systems run 10 to 15 degrees above the thermostat's open temp, so I'd expect yours to be more like 170 to 180 on the high side. I would agree with the consensus writing here that 205 isn't harmful, but it's greater than I would expect with the thermostat you have.
Consider you've changed the heads to aluminum which transfers heat faster than iron, you'd actually find a hotter thermostat reduces the delta T between the coolant and the head which increases the efficiency of the combustion chamber.
I also see you've put on a Flowcooler pump, which causes the question of whether you changed the pulley ratio as well.
Then there's that 3800 RPM stall converter which leads to why (I mean I think I know but tell it to me anyway). High stall converters can dump a lot of heat, if the tranny fluid is exchanging temperature with the radiator coolant, this could be a contributor.
Then comes the question as to the vehicle type, weight, and gearing.
Bogie
  #18 (permalink)
Old 08-31-2010, 10:11 PM
Originally Posted by sickolds
well my car has a chevy 383 and it runs at 180-190 on a regular sunny cali day but the car seems to run better when it hits 200 on a very hot day unless its all in my head
Its not in your head =) you make more power when it runs just that little bit hotter. I tend to race my NASCAR super truck with half the radiator taped off to help it keep between 200-210 and we race for about an hour.
700r4 running hot fenderbender Transmission - Rearend 3 08-13-2007 08:46 PM
700r4 transmission running hot all gm Transmission - Rearend 4 12-08-2006 04:46 PM
2004r's running hot ???? !72chevelless Transmission - Rearend 24 10-08-2006 06:47 AM
Running hot Couplazs Engine 10 06-29-2004 02:58 PM
hot side, 350 tpi engine runs hot on one bank? Ellisb Engine 16 10-27-2002 06:28 AM
