Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - hot to set carb
Thread: hot to set carb
Old 01-13-2006, 09:05 PM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
The idle is set by a screw on the drivers side of the carb, near the bottom about half way back. The two screws on the front control your idle mixture. The check and see if it's rich or lean pull the plugs and look at them. The check and see if it's rich at WOT {wide open throttle} run it wide open in 1st or 2nd gear and kill the engine leaving your foot on the gas. pull the plugs...white or red is hot/lean, brown/tan is good and black is rich....
