hot to set carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2006, 04:27 PM
hot to set carb
i just put an edelbrock carb on my truck, how do i set it, it idles to high and i don't know if the fuel mixture is good, i bought this carb used and did not recieve any instructions
Old 01-13-2006, 06:37 PM
73oldsman's Avatar
I haven't set up one of these but maybe this will help some...http://www.fordmuscle.com/archives/2...ockCarburetor/ http://www.innovatemotorsports.com/r...uning-hero.php and http://www.edelbrock.com/automotive/carb_index.html
Old 01-13-2006, 08:05 PM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
The idle is set by a screw on the drivers side of the carb, near the bottom about half way back. The two screws on the front control your idle mixture. The check and see if it's rich or lean pull the plugs and look at them. The check and see if it's rich at WOT {wide open throttle} run it wide open in 1st or 2nd gear and kill the engine leaving your foot on the gas. pull the plugs...white or red is hot/lean, brown/tan is good and black is rich....
Would you buy the Hot Rod or a Diamond for Your Girl? Tell Us! prismstar Hotrodders' Lounge 2 06-04-2006 05:21 PM
Need help with Edelbrock carb Crazy-J Engine 1 06-01-2005 02:24 PM
What is this crap in my carb? Jmark Engine 7 05-15-2005 07:08 PM
Need some pointers on Holley carb crshrmn3 Engine 2 02-08-2003 11:22 PM
How to ID types of Carb on Tri-Power Set up 66 CT Stang Engine 14 01-29-2003 08:29 PM
