hard starting
hi my name is brad iannotti n,providence R.I. EMAIL iannottibrad@yahoo.com my freinds call me mr.wized i do not know how old you are but remmber the old cadlacs. it sounds what your car is doing yo drive it shut it off and go to start it , it sounds like timing is advanced to death. it is if you have vacum control dist. if you have a check valve it is holding dist advance will it sets vacum slowly leaks out. try running it whit out vacum hook to dist for a test let me know BRAD
Monte
HI ITS BRAD i see you have a monte i have 1987 monte carlo mint engine 200 miles trans 1500 350 roller cam,roller lfters,roller rockers 203 duration .450 lift car is all orginal black red.orange stripes 200r4 shift kit all built car is mint not bad. computor works i like it super chip in computor. but lets get back to yours tell me if it works, remmber its probly holding vacum and dist, is advance all the way when its sitting there for some time it loses the vacum and goes back to where it should be [cars are not sell proof for vacum] my car does not have vacum it is computerrized keep the hope up and if that does not work we will fix it do not worry or get nerves thanks BRAD
I am not sure where it is set now and it was late last night when I finished running the new ground cable and then found that it did not help. I will back the timing down tonight and see if that is the problem,,,it seems to me that that is the only thing left that it could be.
manifold off and on, distributer in and out, hot start problem, now but not before the work preformed = timing to far advanced the shop that did the work should correct that at no charge . Just my first guess.
Sitting in a shop for 6 months is enough to cause corroded battery terminal, starter terminal contacts. Remove and Clean all the connections.
Remove the battery and charge it. It may have sulfated from sitting. Get a heat shield wrap for the starter motor. Replace the GM solenoid. They don't last forever, especially with headers. Install a ignition power interrupt switch to allow cranking the motor over with no spark. Get it spinning then hit the spark. Ignition timing, mechanical advance weights stuck advanced. |
Am going to run the car then pull the coil wire and see how it turns over. The starter is 3 days old,,,the battery is 3 days old and is big,,,,the cables from the battery,,,,2 days old and are so big that I had to use welding connections, Ford solenoid,,,2 days old. I do not have vac. advance,,,running all MSD with mac. advance only. I could have gotten a bad starter but I want to check the cranking with the coil wire pulled and see how it acts.
Like sqzbox said, check for the ground strap. Also, too advanced timing, check spark plug gap (although it wouldn't cause it to crank slowly, it would cause it to be difficult to start when hot). Starter may need to be shimmed just a little; remember metal expands when it gets hot. Just some thoughts.
Just got back from the shop
Put another new starter on and it would not even turn over with a cold starter. Pulled coil wire and still nothing,,,nothing at all. Tried to turn the motor over at the crank and no go.....they are going to pull the pan because they think it is a galded piston or worse.......I may be done with Hot Rods!!!!!!!!!!!!!!
brads auto
FWIW I have been having similar hot start issues with the battery in the trunk.
I tried the ford solenoid, the starter heat shield, grounded both the the battery and the engine block to the frame etc. After trying the above with no success I finally figured out that if you disconnected the HEI wire and just cranked it a few times the starter was almost too hot to touch even with the engine cold.. = ground issue!! I did a lot of reading here and on team chevelle and saw several posts saying that grounding the battery to the frame was not sufficient b/c the frame is relatively flimsy metal etc. People were citing factory assembly manuals which called for battery to block no exceptions. What seems to have solved it for me was running a 2ga ground from the battery in the trunk to the engine block itself (not the bellhousing which is usually aluminum and doesnt conduct well). I also used a separate 2ga ground from a different point on the the block to the frame, a third 2ga ground from the body to the frame and an 8ga ground from the ford remote solenoid to the negative on the battery. Make sure all paint surfaces are clean, bare metal at the connection point - use a dremel or 80 grit sand paper to get to clean, shiny metal. Hope this helps save someone some frustration in the future.. |
What we ended up doing was after driving the car then pulling the starter and putting a cold one on and the motor would not turn over we attempted to turn the motor over by hand. The motor would not turn over when hot = engine problem and nothing to do with electrical or starter. I am going to pull the motor and pull it down and fix it then sell the 600 hp beast and replace it with some type of LS motor and trans.
| BBC hard to start when hot and low oil pressure | inquiring_mind2 | Engine | 19 | 08-26-2009 12:07 PM |
| 1995 trans-am help! | sk8fate | Engine | 12 | 03-14-2009 02:13 AM |
| Chevy hot start | Waylon | Electrical | 6 | 12-08-2007 02:51 PM |
| Hot Start Issues SB 350 | subman17 | Engine | 4 | 11-10-2004 11:00 PM |
| Chevy hot start problems narrowed down | mark2002 | Engine | 7 | 07-03-2003 06:06 PM |
