Mark |
Hey
I am thinking about changing the whole starter...for the price it make sense...I am not sure if heat actually bothers the starter... It might be a common issue...but man what a pain in the butt...my goal is to check all the wires..as i stated i have all my secondary when this happens...so it make me think its not electrical...so i am going to change the starter and get the heat shield wrap and do it up and try that. what do you think |
Make sure you have ,what I call the grounding triangle
Which means grounded from the battery to the frame from the frame to the engine & to the body. Make sure to use the electrical star washers so the make a good connection. Make sure all positive connections are tight & corrosion free. Check Fusible links sometime they will be hanging on by just one strand of wire {corrosion} . Also check to make sure the connections on the starter are tight & corrosion free. Good luck Plus all the stuff mentioned above. R
"SlowRide66" "Illegitimis non carborundum" Don't let the bastards grind you down! Crankshaft Coalition Master List of Hotrodding Forums |
Many times it's the starter solenoid. My Camaro used to go through a starter solenoid a year until I wired in a Ford starter solenoid on the fender away from the headers. You can buy a kit to do that from Summit or Jegs. I haven't had a problem with starting in over 4 years now.
hey, i had this same problem on my truck, found out it was the solenoid wire didnt carry enough volts when hot. went back to 12ga. wire it was fine. most after market harnesess only use 14ga. looses to many volts on a long stretch. some guys went to a ford sol. and use a jumper on the starter. hope this helps.. frank
Starting problems.
I would say that your starter is getting to hot I had the same problem with my truck when I left the heat shield off once I placed it back on it was magic also a BAD ground can cause the same thing hope it all turns out fine, I remember I had a bad coil on my goat it wouldn't start till it cooled down but it would turn over just sharing some info.
| Starter problems.....again, and again | zipfactor | Engine | 32 | 01-05-2012 07:50 PM |
| Chevy 350 cracked starter mounting hole w pics | skiprec | Engine | 15 | 11-11-2011 06:47 AM |
| SBC Starter and flywheel problems | WakBordr7387 | Engine | 18 | 03-05-2011 02:13 AM |
| Would you buy the Hot Rod or a Diamond for Your Girl? Tell Us! | prismstar | Hotrodders' Lounge | 2 | 06-04-2006 05:21 PM |
| Starter Solution | dollybud | Electrical | 0 | 09-30-2003 06:42 AM |
