Hot wheel - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2013, 06:13 PM
Hot wheel
Left Front wheel and rotor too hot to touch after only about 4 miles. Could it be Brake sticking? Others ok, barely warm.
Old 04-15-2013, 06:18 PM
Faith - Respect - Trust
Then I would say that the brake is sticking...but...there must be a reason...has there been any brake work done recently?, did it happen all of a sudden? How do the brakes feel, spongy peddle, hard peddle soft peddle, pulsating peddle? What happened before the brakes started sticking?
Ray
Old 04-15-2013, 06:52 PM
Thanx for the quick reply Ray, Before replacing a wheel hub bearing (LF), yesterday on my daily driver, I noticed the hot wheel. Also had a bit of a roar and narrowed it down to the left front wheel bearing. Got it all back together right before dark. After work today, thought I would just run a short errand, and noticed at the first stop, kinda spongy or soft brake, but did ok at all other stops. When I got home ,thought I'd just touch rim and man it was hot, and of course so was the rotor. Also still have a rparing sound when traveling down the road above 40-45, though not as bad as before the wheel bearing swap. May have another bad bearing. 118,00 miles.
Old 04-15-2013, 07:15 PM
It could be another bad bearing and if your getting the assembly that hot it could be cooking the brake fluid giving you a spongy peddle. Does it pull in any one direction with or without the brake being applied, if it does, then a sticky caliper could be a problem. What kind of car is it?
Ray
Old 04-15-2013, 07:44 PM
This particular car is my get to work and back 2005 Kia Spectra. Did not notice any pull to one side or other. I did notice that the pads will be replaced soon. Not squealing yet, but won't be long. Also, did not go far enough to first stop to heat fluid, I don't think. Maybe 100 yards. I do agree, though, that it could be another bad bearing, even if NEW. I was kinda hoping the bad bearing was on another corner of the car ( I mean the one that might still be causing roar.)
Old 04-15-2013, 09:40 PM
Does this vehicle have ABS? If so did you open the bleed valve when you collapsed the caliper?
BB
April 2012 Hot Rod Art Contest: 1950's Hot Rods Jon Hot Rod Art 43 04-21-2012 05:41 AM
hubless wheel: Swiss company re-invents the wheel Jon Hotrodders' Lounge 28 03-13-2007 02:36 PM
recovering a grant challenger wheel and painting the wheel itself gothrod87 Interior 0 09-14-2006 08:02 PM
Are chrome wheel plugs supposed to be loose in Weld wheel? shockers69 Hotrodding Basics 4 03-01-2006 11:05 AM
