Your courting a fire in the making.. !4 gauge wire is way under rated for the draw your fan (s) are pulling..for starters. The switch is most likely under rated as well..most "off the shelf" switches are rated at about 5 amps continuous contact ratings.. You need to install a relay, and 10 gauge wire. A Fan may "Spike" many times it's rated value under certain conditions. Start up for one..That current that is required for the fan to overcome gravity..Rotor lock is another (a plastic bag sucked up off the roadway) , It can cause multiples of it's regular draw..Obstructions to the air flow..the possibilities are endless..
This will end your heating issues, it will deliver more power to the fan motor, be properly fuse linked, and your car will be less likely to catch on fire. Doc
Aftermarket Solutions Electronic & Electrical Innovations |
I was not correct on the fuse set up. There is a fuse on the battery side of the switch which is 25 amp. I also then found a 25 amp fuse on the output side of the switch, and it is this fuse and the switch that heats up. I assume because it is on the output side. I checked the ground and found it grounded to chasis through the radiator frame (also not good?).
Doc, thanks for the prompt reply, and I will do just as you suggest. Please explain: "Coil power to switch now." "Coil ground to a good bonded hard ground" Are you referring to the Relay Coil? Also, I am not sure of the gauge of the original fan wires, but they don't look like 10 gauge. Will a soldered splice with 10 gauge as close as possible to the fan be OK? (I can't get to the fan itself, as it is in never, never land in front of the radiator and behind the grill). And also, the battery ground cable is bolted to the block, would that place fit your description of a 'bonded' hard ground? Lastly, will I still be able to power the relay with direct twelve volts (always on) so I can use the fan to cool down after engine is shut down. Don't want to use a thermostat. Your answer will as always be appreciated, and I will be able to get busy with the above answers, (sorry for so many questions). rap Last edited by rapsag; 06-18-2006 at 09:41 AM. |
Relay terminals
Got a relay, 30 amp. (no hang up tab was available). There are 4 terminals.
Correct me if I am wrong: 1:Terminals #85 and #86 are the coil terminals and polarity is not an issue? Should I put a smaller fuse in the battery side lead to the coil? 2: Terminal #30 is the power in tab (battery side) and must be fuse linked with say 25 amp fuselink. 3: Terminal 87 (which is turned 90 degrees from the other 3) is the power out to the fan. 10 gauge wire on the high amp side. And is 14 gauge ok on the low amp side as I have some available. I plan to place the relay in the engine compartment as close as possible to the fan, so as to shorten the high amp wire length. Then will run the low amp switch wires from the dash. All will be routed away from the exhaust areas (no problem) Am ready to fly upon your approval or correction of the above. Yes I am compulsive, but it pays. rap |
Run a properly gauged Ground cable from the battery to any handy bolt at or near the starter, From that same bolt get a Battery cable at the parts store, that has two 3/8 ring terminals on each end and attach it there and to the Frame. Next get some 10 gauge wire and ring terminals and run that from your bolt on the block to the Firewall, and another to the Alternator bracket or mount bolt. Next get some Wire Braid, (Radio Shack) and install braid from the radiator support to the frame, Fenderwells to frame , hood to firewall, Doors to door posts, gas flap to body, tailgate / Trunk to body. At each point the wire is grounded, Burnish ALL the paint and grease off to bare metal. Use a proper star-washer and lock. Use sheetmetal or Tech screws where no screws are available. It sounds like a lot of work, but after you assemble all the parts, it's only a few hours to do..and you'll end up with a system that will work reliably for many years to come..and can eliminate that from your troubleshooting list. Quote:
"Coil ground to a good bonded hard ground" <---the other side of the relay coil to a known good ground/body part, burnished surface and a star-washer. Are you referring to the Relay Coil?<---Yes Quote:
No problem! Doc
![]() Just substitute "temp sender for "Ground" in your case..Polarity is NOT an issue..and the fused side of the coil, need only be, 1 amp.. Quote:
The LOW draw side will be the CONTROL wire side, (the coil) Quote:
Doc
Done Deal!
Finished this pm. What a difference a little wire will make. Relay is under hood up front and only got as warm as the other non- engine things. Wires stayed cool. Happy camper. And thanks Doc!
rap |
Doc here,
Pun intended! Thanks for posting back your success! Good to see Positive results.. So now your A FAN of Relays huh?? (OK, enough puns.. )Happy Crusin' Doc
Doc here,
Absolutely SHOCKING! Doc
Aftermarket Solutions Electronic & Electrical Innovations Last edited by docvette; 06-21-2006 at 02:14 PM. Reason: cuz I can... |
Doc here,
I feel like my CONTACT in this thread has been cut SHORT... And headed in a NEGATIVE Direction..However..I do understand your RESISTANCE to my Puns... Doc
| 1 wire or 3 wire alternator??? | oldguy829 | Electrical | 34 | 03-12-2013 10:47 AM |
| wiring diagram | samh | Electrical | 2 | 02-07-2006 06:28 PM |
| Keeps Blowing Fuse | hotrod48 | Electrical | 17 | 09-29-2005 12:20 PM |
| 1986 Cutlass wiring Q's again :( | ChrisMiddleron | Electrical | 12 | 07-16-2005 04:22 PM |
| Basic fuse block rewiring | y5e06 | Electrical | 2 | 06-02-2005 06:46 PM |
