Hot wire to the HEI - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2010, 04:27 PM
Hot wire to the HEI
Please be patient I'm really stupid when it comes to wires. Can I run a wire from the battery to a toggle switch and from the switch direct to the hei or do I have to put a relay in ?
Old 03-07-2010, 04:39 PM
JB Welder
You don't need to do all that. Just run the wire from a 12 gauge supply wire (so it will be fused and thick enough for the power level the hei will draw) from a switched source that is 12 volts hot in key-on and key-start. A multi-tester/volt-meter can verify that. The diagram I posted in the other thread was no help? It is the typical way full size jeepers do the hei conversion, but your 74 may be a little different.
If nothing else, post your question in a Jeep forum they will be more familiar with the wiring system and can probably give you a typical place to pull power from because an hei conversion is a real common mod.
Old 03-07-2010, 05:37 PM
hei
Yes. No relay needed. heavier wire. 8 or 10 ga. Pos side of batt.
Old 03-07-2010, 05:39 PM
ComingApart's Avatar
It won't draw enough current to need a relay.
Provided it's not to small a wire, you can wire it to a switch like you asked about.
Like a previous poster mentioned, an ignition switched terminal in the fuse box would be preferred, but without knowing you application, it may not apply.
Hot Rod Invasion III: August 29th Big Bear Lake, Ca Bombshell-n-ink Hotrodders' Lounge 2 03-23-2010 04:00 PM
How to wire up a points triggered HEI module fiscus Electrical 2 11-16-2007 05:22 PM
Hot wire from hell!!! 78 monte Electrical 3 09-08-2003 01:31 AM
One wire or three wire? Screwy Lewy Electrical 0 06-30-2003 04:33 PM
Wire Looms for 350 HEI with rams horn manifolds Jag Daddy Engine 8 03-17-2003 07:25 AM
