HotRod air gone need help - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2010, 05:50 AM
My air conditioner keeps freezing up. I have tried running on the lowest settings and the blower on high but it still freezes up. Have changed the drain line to assure it has no restrictions. Any suggestions?
Thanks,
Kelso
Old 09-02-2010, 09:40 AM
Wiki Edits: 49
The guy who started Hot Rod Air was one of the guys who also started Vintage Air. They had a falling out and he started his own company. As I understand it the systems are very similar and in some cases use the same parts and pieces. You might try giving Vintage Air a call.
Old 09-02-2010, 02:50 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
I'm assuming it worked OK at one time.
That's a symptom of low refrigerant gas charge.
Or bad expansion valve.
Or insufficient air flow across evaporator coil (inside coil).
vicrod
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 09:09 PM
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
More on Orange Peel KarKen Body - Exterior 36 03-22-2009 02:18 PM
Air Bag cost Non Hotrod rick_458 Interior 5 02-28-2006 05:04 AM
