hotrod black, help I am painting soon - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-28-2011, 10:42 PM
I want to paint my Pontiac hot rod black, I am looking for a satin, just a little more closs then flat. I have taken all the crome off and had it powder coated high gloss black, bumpers too. I have seen some flat black paint jobs that had stains and hand prints on them. I have heard there are some paints with seperate satin clear coats. I have also seen them with the clear coat mixed in the paint. I need to know which one will give me the satin finish and will resist stains. I would also love to know how to clean and care for the hot rod black paint job....Thanks guys for your help
Old 11-29-2011, 01:16 AM
it depends on what sort of paint you wont to use..in the passed i've just sprayed a acrylic lacquer with a clear and have not sanded the last coat..worked for me anyway..pretty hard to pull of a good flat black paint job..and even harder to keep clean.
Old 11-29-2011, 01:33 PM
67Elcamino's Avatar
SEM hot rodz black i great, tcp global hotrod black is good. Do not do it any other way as you might not get sheen you. Want google some sample cars ive seen hundreds in person and the best are those. If your a California theres also PCL flat black
Old 11-29-2011, 10:58 PM
67Elcamino's Avatar
You can wash with any no wax car wash its actually pretty fade resistant its just very difficult to blend if you get scratches or nicks its pretty durable
Old 12-02-2011, 08:59 PM
86GMC's Avatar
auto/truck/equipment tech.
What year's your car? i have a 53 pontiac pathfinder i did in RM semigloss black, and gloss black on the chrome. Cant help you on care, but if youre early 50's i can give an idea what it will look like.
Go easy on me, its a work in progress
Old 12-02-2011, 10:00 PM
kustom shop hot rod flatz. The easiest most durable satin paint I've ever sprayed! Very forgiving and almost impossible to make a run.
just as durable as any other single stage urethane! (and no, I don't work for KS) I've just enjoyed spraying their paints enough that I like to share.
Old 12-03-2011, 09:53 AM
S10xGN's Avatar
Gotta love a turbo!
Agreed! I've used it before and it's really good stuff. For the OP, just be aware that humidity will affect the degree of "sheen" along with between-coat timing. Consistency is the key!
Russ
Old 12-03-2011, 10:10 AM
I ahve used rustolum semi gloss black & is a perfect match for the ppg-epoxy primer .
It comes in a qt can white & green has a picture of wrotiron patio chair on it.
I put a little epoxy harder in it & the finish is very durable & can be washed
SEM HotRod Black opinions BMM Body - Exterior 4 02-04-2011 02:14 PM
Sem hotrod black 71broncrollsport Body - Exterior 1 10-25-2010 04:38 PM
hotrod black comparison? runn141 Body - Exterior 3 05-30-2008 09:04 PM
another hotrod black ? runn141 Body - Exterior 1 01-13-2008 11:29 PM
hotrod black sanding racer2312001 Body - Exterior 6 09-23-2007 07:07 PM
