Hotrodders EFI Dream Come True
Or at least mine.
What do you guys think about this? This is a trick new EFI setup from Retrotek Speed. Check this out |
I'm gonna be a bit skeptical on this one. How does it monitor atmospheric conditions, exhaust conditions, engine temp, and such. Those are all parameters that a good fuel management system needs to adapt to. Just plug it into your computer and choose a setup that is most like your situation....I don't think so. We will have to wait and see on this one, but I'm not holding out much hope.
Vince |
It appears to be a Speed Density system with the ability to learn as it goes. Similiar but more advanced than the HOLLEY TBI System.
Need a little more tech on it but I bet BG is wondering...
It is a hotrodders' dream. No complicated hookup. |
Its got my attention. I could not find anything about the blowers. It did say it was compatible for superchargers and turbo applications, but I did not see anything about big blowers. I wander if you can run twins on a roots style blower? I will e-mail and see what they say.
It sounds great if it does what it is advertised. Once it is out and people start using it we will know for sure. Granted it would be a dream come true for sure
Saw a post on another forum that had the price at around $2000. Vince |
Looking at the wiring harness there are 8 connections.
The carb/EFI has 2 connectors (TPS & Fuel injectors). Some of the other connectors are for MAP, temp, WB O2, fuel pump. The other 2 may be for atmospheric pressure, maybe a VSS or knock sensor also? |
That's a pretty cool setup if it lives up to it's claims. I thought of it before (I'm sure many others have too) but don't have the resouces to build it.
Looks like they have a throttle postion sensor built into the throttle body and maybe that is also where they are getting the manifold air pressure reading, probably from the base of the unit (although that loocation wouldn't work for a typical blown motor). That helps keep it clean. You will have to install an o2 sensor in you exhaust though. I like the idea of the pulse width modulation of the fuel pump, thats a pretty creative way of doing it, as long as the pump survives the variable speeds. It will be interesting to see how they handle startup, acceleration, warmup as those conditions all require very rich mixtures which will be different for every motor as the 02 reading won't be much help under those conditions. They should be able to capture atmosphiric pressure on startup, thats how megasquirt does it. I still prefer the bugcatcher for my EFI
| Hotrodders Guidelines -- READ ME | Jon | Body - Exterior | 0 | 06-14-2003 05:00 PM |
| Hotrodders Guidelines -- READ ME | Jon | Interior | 0 | 06-14-2003 04:59 PM |
| Hotrodders Guidelines -- READ ME | Jon | Transmission - Rearend | 0 | 06-14-2003 04:58 PM |
| Hotrodders Guidelines -- READ ME | Jon | General Rodding Tech | 0 | 06-14-2003 04:57 PM |
| Hotrodders Guidelines -- READ ME | Jon | Engine | 0 | 06-14-2003 04:53 PM |
