How accurate is DD2003? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2010, 11:04 AM
Hi. I was just wondering how accurate Desktop Dyno 2003 is? I built an engine and it comes up with 548 hp at 6500/ 503 ft/lb TQ at 5000, at the crank.
385 sbc
11:1 compression forged flat tops
dart Pro 1 200's aluminum 2.02/1.6
solid roller (lunati 50169) .606/.587 248/252 @ .050
vic jr single plane port matched
750 quick fuel dp
1 3/4 primary tube 3 1/2 collector headers
sounds kind of high to me. Plus I think the carb may be too small, bad hesitation when you stab it at a stand still, it cuts out.
Thanks
Old 05-13-2010, 11:05 AM
How fast is fast enough?
sounds like you need a carb, but that could be pretty close. Only one way to know for sure.
Usually its about 5% over the top.
Old 05-13-2010, 02:41 PM
Do you think an 850 is appropriate? Im in salt lake city, utah abt 4500 elevation
Old 05-13-2010, 02:49 PM
Jesus that's high! I'm at like 400ft. If you're thinking of going with a different carb a custom one would be well worth the money IMO. you're only looking at a couple hundred more and a good tuner can get that thing dialed in perfectly- which is harder than you think to do in your own garage.
Call up a couple carb shops and tell them what you have and what you want. Most of the better shops will work with you.
Old 05-13-2010, 02:51 PM
thanks for the advice
Speeddometer Not Accurate MUR317 Transmission - Rearend 3 10-14-2008 07:19 PM
need accurate DD2000 info 64SSOwner Engine 4 06-19-2005 12:09 PM
Which temp gauge is more accurate Palmtrees57 Engine 3 10-30-2004 06:38 AM
Accurate Transmission RULES k2mooch Hotrodders' Lounge 1 12-29-2003 06:26 PM
accurate + descriptive titles Jon Hotrodders' Lounge 5 09-08-2003 11:17 AM
