Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - how to add stripes with bc/cc system
Old 08-21-2012, 03:39 PM
302 Z28's Avatar
302 Z28 302 Z28 is offline
The way I would do it is lay down your base coats first and within the window for applying clear (usually within 24 hours) tape off the stipes and apply base stripe color. Allow base stripe color to flash properly then apply a lite coat of clear overall. Follow with sucessive coats of clear.
If you apply the stripes after applying clear depending on the color you may wind up with a look like the strips are raised off the base.
Vince
