Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - how to add stripes with bc/cc system
Old 08-23-2012, 06:22 PM
astroracer's Avatar
astroracer astroracer is offline
Every layer of paint you lay over the tape will add to the thickness AFTER you remove the tape. Also, the paint will "gather" at the tape and create a higher edge then in the middle of the stripe.
I would use single stage and shoot only enough paint to get coverage. After it cures you can sand the edges and polish to reduce the edge thickness.
Mark
