how to add stripes with bc/cc system - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2012, 03:13 PM
hello
im planning to add stripes on my car , using bc/cc
i would like to get some advise
i know it will be better to spray the base coat , take of the tape and clear the whool panel
but here i would like to know , if i just clear just over the stripes ( and after take of the tape )? m I going to get a sharp line ? a fragil line?
thanks
Old 08-21-2012, 03:39 PM
302 Z28's Avatar
The way I would do it is lay down your base coats first and within the window for applying clear (usually within 24 hours) tape off the stipes and apply base stripe color. Allow base stripe color to flash properly then apply a lite coat of clear overall. Follow with sucessive coats of clear.
If you apply the stripes after applying clear depending on the color you may wind up with a look like the strips are raised off the base.
Vince
Old 08-21-2012, 04:13 PM
im not doing an entire paint job
the car is paint already
and the fact than you can feel the stripes , i like its like original ( its for a 72 CUTLASS)
Old 08-21-2012, 04:35 PM
I had seen a good idea Brian mentioned, which was just to spray single stage for the stripes.
Old 08-23-2012, 03:02 PM
i would like to use metallic paint
you think single stage its a good way to go ?
Old 08-23-2012, 03:26 PM
1pickup's Avatar
Flathead Freak
stripes
scuff the entire panel, tape & paint stripes, clear, done
Old 08-23-2012, 04:28 PM
can i clear just the stripes and then remove tapes ?
Old 08-23-2012, 05:22 PM
astroracer's Avatar
Every layer of paint you lay over the tape will add to the thickness AFTER you remove the tape. Also, the paint will "gather" at the tape and create a higher edge then in the middle of the stripe.
I would use single stage and shoot only enough paint to get coverage. After it cures you can sand the edges and polish to reduce the edge thickness.
Mark
Chevy 454 FI propane add on system vtflatlander1 Engine 4 07-20-2011 12:12 AM
Stripes sapsz28 Body - Exterior 15 04-01-2010 01:44 PM
stripes sapsz28 Body - Exterior 4 03-10-2009 10:16 PM
Cooling System-Open System vs Closed System smokey626 General Rodding Tech 4 02-14-2009 07:34 PM
Vinyl stripes vs. painted stripes? idexbryan Body - Exterior 6 05-04-2006 07:07 PM
