How to adjust column switch hi-low beams?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2007, 05:50 PM
Greetings from Alberta,Canada
The Car: 1983 Cadillac Fleetwood
The Problem: High beams will not stay on.
This car uses the high-low beams mounted on the turn lever,the rod and the lever are in good working order,a new switch was installed,and it's still not working correctly.I see the switch has elongated holes and I've tried lots of adjustments with the same results.I can pull the brights on but they won't stay on,it clicks back to low everytime.
Somebody shoot me some tips please.
Thanks-Hoonbash
Old 06-24-2007, 06:14 PM
Try moving the switch in the opposite direction I think it sits in the low beam position moving it one way flashes the hi beams and the other way keeps the hi beams on.
Old 06-24-2007, 06:26 PM
Nope that didn't work either,the switch will only go one way.It does have the ability to flash the highbeams,it just wont keep em on.
Thanks for the reply-Hoonbash
Old 06-24-2007, 06:49 PM
Some have a ''flash'' , where you can flask tour highs at some one ( like the other post said, and then you push the lever the other way to click them on. I assume you found that already. Then next, I would unhook the rod and move the rod up or down, or take the rod out completly, click the flasher.....................new parts are not always good parts.
Trinary Switch from Vintage Air ElegantInventor Electrical 29 06-15-2011 06:44 PM
GM switch info(application) sha_ba_do_bang Electrical 5 10-22-2006 11:01 PM
New harness install, now some questions Blackdog Electrical 5 10-06-2005 11:19 PM
Steering Column Harness on a G-body 1982 SS Electrical 2 07-29-2005 01:06 PM
'96 Chevy Truck - no low beams 56Thunder Electrical 5 02-14-2005 12:37 PM
