Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to adjust column switch hi-low beams??
Old 06-24-2007, 05:50 PM
Hoonbash Hoonbash is offline
Greetings from Alberta,Canada
The Car: 1983 Cadillac Fleetwood
The Problem: High beams will not stay on.
This car uses the high-low beams mounted on the turn lever,the rod and the lever are in good working order,a new switch was installed,and it's still not working correctly.I see the switch has elongated holes and I've tried lots of adjustments with the same results.I can pull the brights on but they won't stay on,it clicks back to low everytime.
Somebody shoot me some tips please.
Thanks-Hoonbash
