How to adjust kick down - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2005, 12:03 PM
western star's Avatar
What is the proper way to adjust the kickdown. I have a 727 trans, Holley 670 Street Advenger and Lockar adjustable cable. It's been awhile and I'm not sure.
Old 05-28-2005, 01:48 PM
Ok I figured it out and now everything works fine except.....I have kickdown under 40 mph but any faster it won't drop from 3rd to 2nd with foot planted to the floor. Is this still in the adjustment? It would be nice to have passing gear on the highway.
Old 06-02-2005, 08:45 PM
Hold the trottle wide open with your hand, the kickdown should be tight when it is wide open. Always adjsut your kickdown with the throttle held wide open, this way it will kick down at wide open throttle, like it's supposed to.
Old 06-03-2005, 03:22 PM
Yup I got it working thank you.
Adjust Edelbrock Carb bezmanianm Hotrodding Basics 9 06-15-2004 04:09 PM
Kick down cable magic781 Engine 6 06-09-2004 08:56 PM
valve adjustment 383 stroker solid lifter cam 73luvdrag Engine 4 05-15-2004 03:01 AM
Please HELP valve adjust? 1985fiero Engine 10 05-03-2004 06:50 PM
kick down cable gumby Engine 2 06-12-2003 12:22 AM
