If the valve springs are old or don't match the cam it would be the first thing to look at, but there are other things that can produce like symptoms. The rpm point you describe is the typical point for valve float to occur with weak springs.
Cam should run right up to 6000 easily, might be done on power ar 5500-5800 but should have no problem revving to 6000+. A little more detail about the engine would help - carb, intake, headers or not, ignition initail timing and total timing, fuel pump size and line size, anything else you want to add to help pin things down. |
That is a pretty mild cam. 205 is your intake duration @ .050 lift. 215 is your exhaust duration at .050 lift. (This is how long your valves stay open)
The 112 is your lobe seperation. (How far apart, in degrees, that your intake and exhaust lobes are.) The 450 is your intake lift and the 475 is your exhaust lift. (How far the valves open) IMO this cam will be fine with stock heads/valve springs. Im not sure where the cam stops making power, but its probably some where around 5,000 RPM. The cam will most probably have a stock sound, maybe a little chop, but not much with that 112 Lobe seperation. If you are "running out of power" that low in the RPM range, it could be a number of things. (Carb, timming, week valvesprings causing valve float, etc.) I hope I answered your question... Chevyguy13 Last edited by chevyguy13; 09-21-2010 at 08:34 PM. |
45-4750RPM seems just too low to stop making power. As for the engine specifics: Holley 600cfm carb out of the box no adjustments made Weiland Dual plane intake 7013 I think? Pertronix Billet Dist vacum advance and MSD 6a Ignitor, flame thrower coil timing is currently at 15 degrees BTDC I believe or after? I just remember marking 15 and 0 on bal. Read that 15 is the way to go... Sanderson Shorty headers Fuel pump is a Holley HP, I think its 7 PSI internal regulator. I have not measured vacum Fuel line is 3/8 Hard line from pump to 3 feet before carb, then filter to carb. |
http://performanceparts.com/part.php?partID=183135 You should also realize that more spring pressure puts more stress on the lifter/lobe interface, so you want to start covering your butt with extreme pressure lubricants in the oil. Here is a list of screw-ups that a fellow can do when installing a flat tappet cam. I suggest you read them over and take the appropriate action....extreme pressure lubricants that used to protect the cam have been removed from off-the-shelf motor oils because they plugged up catalytic converters, costing the OEM auto makers money on warranty claims. http://www.crankshaftcoalition.com/w...ips_and_tricks |
What would cause the engine to reach 4500 RPM shift to third (C4 trans) then goes down to 4k and hangs there for a few seconds then starts to build again but the engine seems to be maxing out- not making much power after that. That intake I have is in the 3500-6500 RPM range. |
There arnt any rocker studs- ITs the fulcrum style rockers with a bolt. Non adjustable |
Besides the possible valvespring issue, Could be timing, but I'm thinking small engine size versus vehicle weight, it just can't make enough power to pull well in third gear, not enough torque or torque multiplication. The 5.0l 302 Mustangs are the same way unless they have a lot of gear in the rear axle.
Intake is a Weiand Action Plus 8124- "for engine speeds of 5500 Am I just at the top of this thing or can I squeeze more power out of it. It aint doing it for me...
2400 stall converter, 3:25 rear gears in Ford 9" with the C4 Tranny off the line its ok but not impressed at seat of pants... Cruising on the highway is easy 2500 80 MPH...I like this but want to keep making HPs and torque for atleast a little while after 3rd gear... |
| Least aggressive method to remove sand scratches | Notahotrod | Body - Exterior | 5 | 02-10-2009 08:58 AM |
| Shaker Hood Suggestions | wazzu firebird | Body - Exterior | 15 | 01-07-2008 07:22 PM |
| i need camsahft for lt1 engine? | nokia | Introduce Yourself | 1 | 10-12-2006 06:19 AM |
| Talk about passive aggressive, lame neighbors. | killerformula | Hotrodders' Lounge | 39 | 10-24-2005 05:28 PM |
