How to aim headlights? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-03-2008, 09:06 PM
Well this time, I have a question for my daily driver, an '84 Chevy Caprice:
the headlights are way off and I need to know how to aim them properly.
Not which screws to turn, but where to aim them. I remember seeing a long time ago a drawing on how to trace a line on a wall, park the car in front of the wall and use this line to aim the headlights. That is the kind of help I am looking for, the line on the wall, or any other method I can do at home.
Thanks!
Old 12-03-2008, 09:36 PM
head light fix
ya that's the way to do it, just pull your car up to the garage ( you need to be on level ground) about 5 to 6 feet away pointing straight/ even with the garage door and aim away. the lights should be about the hight of your Knee's give or take a few.
then drive and see if it is to your likeing. if not repet to proper hight.
later josh eagan
Old 12-03-2008, 11:18 PM
http://www.danielsternlighting.com/tech/aim/aim.html
Old 12-04-2008, 05:35 PM
ya that will work also
ya that seems like it would work.
Old 12-04-2008, 05:51 PM
Cape Cod Bob's Avatar
great sit jim
Old 02-06-2009, 02:36 AM
Headlight aim
When using the garage door alignment method, start by aiming the high beams. These should be directly in front. Imagine a cross in the center of each beam and switch to low beam. The candlepower will drop down and shift to lower right quadrant to direct away from on-coming traffic. Adjust each lamp level to the other and slightly higher if during test drive you over-drive your headlight distance.
1939 Plymouth Headlights; Halogen Replacements and Missing Sockets hduff Electrical 5 02-12-2008 11:30 AM
1973 Nova Headlights Andrew61987 Electrical 9 02-05-2007 09:05 PM
Reverse Lights and Headlights evltwin Electrical 1 06-01-2005 06:20 PM
French Headlights D M N Body - Exterior 17 07-15-2003 01:04 PM
headlights 67rscamaro Electrical 4 03-07-2003 07:22 PM
