-   -   how to ajust TV cable on the 700R4 (http://www.hotrodders.com/forum/how-ajust-tv-cable-700r4-104962.html)
k-1500.coy 12-21-2006 06:19 PM
What it the proper way to adjust th TV cable on A 700r4. The 700r4 is in a 84 chev 4x4 full size having problems shifting. Help
pasadenahotrod 12-21-2006 07:04 PM
Google "700-R4 Tv cable" and check adjustments procedures from Transmission suppliers. It is fairly easy but it is critical that it be right, so follow some version of the factory method so you don't smoke that expensive transmission!
38Chevy3WCoupe 12-21-2006 07:29 PM
Go here:
http://www.tvmadeez.com/article/index.html
37ford4dr 12-21-2006 10:03 PM
after i installed the engine and trans in my vette i dropped the trans pan and had some one step on the gas pedal to WOT and i watched the plunger in the trans and adjusted it so that the plunger was depressed according to the specifications.....it certainly was the easiest way for me to do it.
39 chev 12-22-2006 05:30 AM
how to adjust tv cable on a 700r4
I am no transmission expert,but I do know this is no place for trial and error unless you have lots of time and money to spare.I personally know 2 local hot rodders who have smoked those trannies because of improper adjustment on the cable.I beleive in doing most of my own work,but I cant afford to screw up something as costly as a 700r4 trannie.find someone who knows how,I am sure it wont cost you much to get it done correctly. ;)
