how to ajust TV cable on the 700R4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-21-2006, 06:19 PM
What it the proper way to adjust th TV cable on A 700r4. The 700r4 is in a 84 chev 4x4 full size having problems shifting. Help
Old 12-21-2006, 07:04 PM
Google "700-R4 Tv cable" and check adjustments procedures from Transmission suppliers. It is fairly easy but it is critical that it be right, so follow some version of the factory method so you don't smoke that expensive transmission!
Old 12-21-2006, 07:29 PM
Go here:
http://www.tvmadeez.com/article/index.html
Old 12-21-2006, 10:03 PM
37ford4dr's Avatar
bobs77vet
Last journal entry: frame repair
after i installed the engine and trans in my vette i dropped the trans pan and had some one step on the gas pedal to WOT and i watched the plunger in the trans and adjusted it so that the plunger was depressed according to the specifications.....it certainly was the easiest way for me to do it.
Old 12-22-2006, 05:30 AM
39 chev's Avatar
Last journal entry: new pictures of T-bucket
how to adjust tv cable on a 700r4
I am no transmission expert,but I do know this is no place for trial and error unless you have lots of time and money to spare.I personally know 2 local hot rodders who have smoked those trannies because of improper adjustment on the cable.I beleive in doing most of my own work,but I cant afford to screw up something as costly as a 700r4 trannie.find someone who knows how,I am sure it wont cost you much to get it done correctly.
700r4 TV Cable Problem jack71 Transmission - Rearend 7 10-25-2006 08:05 PM
700R4 - TV cable tension problem wont allow WOT AussieModder Transmission - Rearend 4 07-02-2006 02:47 AM
