How to align camaro sub frame? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2007, 07:55 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
When I did my frame off deal on my 67 camaro I used the info in my HPbook to align my sub frame. It said to simply use some large bolts and put them threw some special holes and that would get the frame aligned..... I don't remember the details but I know their must be a better way to make sure it is right where it should be. I would like to know how to check alignment. Where to measure and anything Else that might be useful. I want to make sure the frame is where it should be before I try and align the sheet metal.
Thanks guys.
Old 03-27-2007, 09:39 PM
If you want there is a place like 10 miles away from my house here in Ohio called Cam-Bird that deals with fiebirds and comeros from first gen up! the Number is 1-330 549-3685 the guys name is John... tell him u herd about him from me "Rob Lancey" he has and knows EVERYTHING!~
Old 03-28-2007, 07:07 AM
Big Mouse's Avatar
Stroked Z28
Note sure on the 1st gens, but here is how it goes on the 2nd gens (perhaps it is the same?):
You have 6 body mounts:
2 by the radiator
2 by the toe boards
2 by the front seats
The 2 toe-boards mounts have an extra hole in the body mount bracket. That hole corresponds to a hole in the body. You slide a body mount bolt in those two hole on both sides of the car. This should get your subframe in alignment. Once bushings are tightened, pull out the bolt... Don't slide the bolt in too far or you'll have a hard time getting it out with the bushings installed...
I found that the body mount bolts was a perfect fit for the alignment holes.
Old 03-28-2007, 09:38 AM
CDJr's Avatar
Experienced Amateur
Last wiki edit: Automobile body and frame rotisserie
Wiki Edits: 2
This should help.
http://home.sport.rr.com/cdjrracing/f-bodyframe.htm
Old 03-28-2007, 10:34 AM
weirdbeard's Avatar
1976 Ranchero GT
Yes Big Mouse I guess they are about the same. Thats what I did with the bolts to get the frame in the ball park. I just want to check to make sure it is right on.
CDjr That is exactly what I was looking for! Now I know how to measure it.
Thanks guys!
Old 03-28-2007, 10:44 AM
dawg's Avatar
NAVY VETERAN
make sure you measure diagonally between the 2 sides of the frame.
they should be the same
28 body doesn't seem to fit the frame oldguy829 Body - Exterior 17 11-28-2007 02:39 PM
86 s-10 frame bent catscan4free Suspension - Brakes - Steering 3 03-27-2007 09:46 PM
sub frame attachment Ricky Rocket Suspension - Brakes - Steering 4 09-18-2005 09:59 PM
Nova and camaro sub frame same? Pro1972nova Suspension - Brakes - Steering 2 01-28-2003 09:24 AM
Frame desighn help Halloweenking Suspension - Brakes - Steering 6 04-24-2002 04:38 PM
