How am i supposed to wash floor pans out before POR15? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2004, 09:57 PM
I just replaced the LH and RH back floorpans in my 68 Camaro and i am going to POR the entire floorpans the instructions say to marine clean then wash out and then metalready and also wash out.My problem is how to get the water up from the floor pans since my replacement pans have no body plug holes like the original pans did.Looks like i will have to sponge it up or cut the holes out on the new pans and then use body plugs.Any one else have this problem?
Old 04-20-2004, 08:04 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
I use a towel and air. I would not cut the floor.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Old 04-20-2004, 11:33 AM
RJL's Avatar
RJL RJL is offline
Towel would be fine then air dry.Just be sure you use a clean towel because any contaminants will effect the POR. If you use compressed air be sure your air is dry.Any moisture in your line that gets on your floor board will cause a large fish-eye problem. Please remember to use a respirator, this stuff is powerful.
Old 04-20-2004, 11:53 AM
79 camaro 454's Avatar
strip the interiour and get a hose pipe bit of fairy liquid or somthing and scrub..well thats what id do
