how apply clear coat when the base coat was apply a while ago - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2011, 05:10 PM
hello everyone
i sprayed my car a week ago ( just the base coat )
the paint is a metallic paint
it's a home garage projet
i'm waiting for a better weather for the clear
but my questions are
when i'm going to spray the clear coat , before
what should i do ?
just using a clothe cleaning ( type taks rags ) all around and spray ?
scuff a little ?
I'm waiting for your sugestions
thanks a lot
Old 07-14-2011, 06:15 PM
Originally Posted by Vincentnova
hello everyone
what should i do ?
scuff a little ?
thanks a lot
what kind of paint. what does the tech sheet say?
Old 07-15-2011, 05:49 AM
BarryK's Avatar
Like freethinker said you need to get a tech sheet or call the paint jobber.
In last year or so a number of the high grade bases have finally came out and said you have an indefinite re-coat window, everyone has known that for years but some of the companies have now made it official.
If you used activator in the base that will also change things, so let the jobber know, when you ask the question.
Also there are one or two crap bases that you cannot sand and re-coat without paint falling off, so you need to hope, that one of those bases are not on your car or you can start stripping.
Old 07-16-2011, 03:08 PM
ok thanks guy
it's a NASON full base voc 3.5
i took a look at the tech sheet and find nothing realy helpful to me
http://pc.dupont.com/dpc/en/US/html/...ase_3-5_BC.pdf
may be I' m going to call
Old 07-16-2011, 04:01 PM
Last journal entry: Hood
I know what you mean Barry, I have experienced that one. But how much does it change when activator is used with the base?
Old 07-18-2011, 10:31 PM
the shop from where I've got the paint told me today , to use 1200 grit wet sand before apply the clear
daimn next time i won't wait so far for the clear.............
Old 07-19-2011, 11:19 AM
67Elcamino's Avatar
Becarefull
I dont believe you can sand a metalic finish before applyong clear inless you plan on recoating with base again. i triEd doing so with a HOK metallic and didnt work
Old 07-21-2011, 10:10 AM
basecoats normally need to be cleared within 24 hours.
Best bet is to scuff it over,spray another couple of coats of base and then clear.....the same day !
Old 07-21-2011, 10:14 AM
THANKS , yes I'm going to do that
Help with PPG Deltron base coat paint and clear coat Please smithkustoms Body - Exterior 31 01-12-2012 07:43 AM
Base coat/clear coat urethane over acrylic enamel mervhudson Body - Exterior 5 04-23-2011 10:56 AM
Couple of base coat/clear coat questions bigbrowndog Body - Exterior 17 11-05-2010 08:37 AM
Base coat clear coat repair problem TimeBandit Body - Exterior 2 09-03-2008 06:22 PM
laquer primer/ppg base coat/clear coat? dave mc Body - Exterior 5 10-11-2005 04:59 AM
