Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to apply waterborne wax and grease remover?
Old 07-30-2010, 11:57 AM
MARTINSR MARTINSR is offline
Originally Posted by panelwagon62
Martin, thanks for the clarifcation!! But I have always used solvent bourne and this is the first time with water bourne so I wasn't sure if the same basic rules applied.
More clarification. You CAN clean off a base coat with the waterborne wax and grease remover. If you were to know or suspect something got on it, the waterborne wax and grease is the stuff to get it off. But wiping down between base coats or clear coats is NOT usually done.
