Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to apply waterborne wax and grease remover?
Old 07-30-2010, 01:43 PM
302 Z28's Avatar
302 Z28 302 Z28 is offline
More clarification. You CAN clean off a base coat with the waterborne wax and grease remover. If you were to know or suspect something got on it, the waterborne wax and grease is the stuff to get it off. But wiping down between base coats or clear coats is NOT usually done.
Exactly, it's been so hot around here that by the time you make your way around a car with the first coat it's time for a second. If you pause to wipe it down between coats you will probably have to scuff before the next coat .
Vince
