How to apply waterborne wax and grease remover?
Ok I just picked up a gallon of spi WB wax and grease remover. One question, do I spray it directly on to the panel then wipe off, or spray a rag with it, wipe down the panel then wipe off with another clean rag? If not what's the reasoning? Thank you
either way is fine..spray directly for intial cleanup and spray a bit on a clean cloth for tacking between coats..do yourself a favor and get a big box of the white lint free cleaning cloths from somewhere..only wipe in one direction and not in circles until no more dirt shows up on the cloth..
Sam |
Alright thanks for the tips. The wipes we use at our shop are by kimberly clark and they are called "wype-all" but I don't believe they are lint free.
Wype-All are OK, that is what I use. Be sure and wipe the surface dry and do not let it evaporate dry.
Vince |
Just to clarify for Panelwagon Brian |
Martin, thanks for the clarifcation!! But I have always used solvent bourne and this is the first time with water bourne so I wasn't sure if the same basic rules applied.
Brian |
Vince |
The base is so touchy that keeping the area clean and simply leaving it untouched throughout the application is best. Brian |
Scuff between coats of base?? Why would you?
Brian |
Being more clear...While in a perfect world we should not need to scuff or tack between coats of base and clear we do need to inspect between coats to see that no bugs or dust bunnies have up and bit us..and if so we need to fix that issue before proceeding with the paint job...then if one has been bitten then we do what we have to do..
Sam |
alright, i think i may have misunderstood what was said. Got it now.
| All times are GMT -6. The time now is 12:43 PM. |
