How to apply waterborne wax and grease remover?
Ok I just picked up a gallon of spi WB wax and grease remover. One question, do I spray it directly on to the panel then wipe off, or spray a rag with it, wipe down the panel then wipe off with another clean rag? If not what's the reasoning? Thank you
either way is fine..spray directly for intial cleanup and spray a bit on a clean cloth for tacking between coats..do yourself a favor and get a big box of the white lint free cleaning cloths from somewhere..only wipe in one direction and not in circles until no more dirt shows up on the cloth..
Sam
Alright thanks for the tips. The wipes we use at our shop are by kimberly clark and they are called "wype-all" but I don't believe they are lint free.
Martin, thanks for the clarifcation!! But I have always used solvent bourne and this is the first time with water bourne so I wasn't sure if the same basic rules applied.
You CAN clean off a base coat with the waterborne wax and grease remover. If you were to know or suspect something got on it, the waterborne wax and grease is the stuff to get it off. But wiping down between base coats or clear coats is NOT usually done.Brian |
.Vince |
The base is so touchy that keeping the area clean and simply leaving it untouched throughout the application is best. Brian |
Scuff between coats of base?? Why would you?
Brian |
Being more clear...While in a perfect world we should not need to scuff or tack between coats of base and clear we do need to inspect between coats to see that no bugs or dust bunnies have up and bit us..and if so we need to fix that issue before proceeding with the paint job...then if one has been bitten then we do what we have to do..
Sam
alright, i think i may have misunderstood what was said. Got it now.
| what else in in wax and grease remover besides mineral spirits? | Dubz | Body - Exterior | 47 | 06-19-2010 12:09 PM |
| Before base coat, use of wax & Grease remover | rodder1 | Body - Exterior | 9 | 03-15-2009 09:11 AM |
| Glass cleaner after wax and grease remover? | wreckedGTI | Body - Exterior | 20 | 06-17-2007 05:21 PM |
| Wax and grease remover on bare ABS plastic, what now? | GMW | Body - Exterior | 5 | 12-26-2006 01:44 PM |
| wax and grease remover - non waterborne bad? | pigman | Body - Exterior | 12 | 08-30-2005 06:57 AM |
