Hotrodders Bulletin Board > Tech Help> Interior
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 06-10-2003, 03:33 PM
rodd1 rodd1 is offline
New Member
how to attach door panels
what is the best way i have tried the 3m duloc junk
it is on a 31 5 window fabric is on the pannels and dont want to use screws the pannels are plastic
  #2
Old 06-10-2003, 09:29 PM
horvath's Avatar
horvath horvath is offline
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
My favorite so far is 3M Super 77 Multi-Purpose Adhesive contact cement. It comes in a rattle-can ... I buy mine from Home Depot ... spray both parts, wait 30-secs and attach parts together.
Alan
54 Chevy Pickup
Old 06-11-2003, 12:00 AM
kristkustoms's Avatar
kristkustoms kristkustoms is offline
First name...............Shawn
I think hes talking about attaching the panels to the door. Velcro or Dualoc (heavy duty velcro) never work for door panels. With the fabric already glued to the panels, this creates a problem. There is a certain type of metal spring clip used to attach panels that can be slipped on from the rear of the panels. You would need to drill a 1/4" hole in the panel and in the door. Drilling a 1/4" hole in a door panel already covered is obviously not an easy task, hopefully the panel has a layer of foam inbetween the panel and the material.
Old 06-11-2003, 09:04 AM
New Member
yes i can still drill into the plastic and if i have to recover i can i getting tired of them fall off where can i get thr clips and i think there is hole all around the doors now for this
Old 06-11-2003, 09:59 AM
Centerline's Avatar
Centerline Centerline is offline
HotRodsAndHemis.com
Last wiki edit: Mopar Tapered Axle Rear Brake Conversion
Wiki Edits: 49
I have to disagree about the Dualoc. The stuff that RodDoors provides with their system works very well.
Old 06-11-2003, 10:16 AM
New Member
that is what i have and it wont even stick to there pannel plus it raises the pannel to far out for my taste
Back to top
Search this Thread:
Advanced Search
vB code is On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
