How to attach a padded piece on '29 body - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2009, 11:00 AM
Trying to figure out how to add a padded piece on the top of the back channel on a '29 body. Would drilling small holes for some type of fasteners (like a door clip) work? How about the area close to the door opening? Any help is appreciated. Hopefully I can figure out how to attach pictures so you can see what I am talking about. PS - the dash piece has carriage bolts on the underside of the wood to attach to the dash (tuck and roll was a result of DanTwoLakes tutorial on tuck & roll, thanks Dan!)
ID:	40312   Click image for larger version
ID:	40313   Click image for larger version
ID:	40314   Click image for larger version
Old 08-30-2009, 08:07 AM
DanTwoLakes's Avatar
Wiki Edits: 22
I think I would fabricate a piece, or pieces, to permanently attach to the car from door post to door post. Then I would build something "U" shaped like a padded rail on a waterbed to slip over that and screw it down in between the tucks. You could use something like hardwood plywood so that the pieces don't warp over time. I don't think attaching it with clips would be solid enough.
Old 08-31-2009, 01:06 PM
padded channel cover
Dan, thanks for the great idea! I probably didn't explain properly that he doesn't want it attached to the 'body' but rather to cover the open area between the back wall and the body..the "U" shaped rail is still 'perfect'! I think we can attach a "U" channel near the front of the plywood to go over the square tubing and then screw the plywood down to the cross brackets...wish me luck
Old 08-31-2009, 02:11 PM
Wiki Edits: 22
Just make sure you make it loose enough that it will go on easily, without forcing it on in any way. That way you'll have some adjustment. Test fit it a lot. It should work out fine for you.
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
34 Ford body alignment 302 Z28 Body - Exterior 5 08-20-2012 06:10 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
One piece or two piece drive shaft junkyardjeff Transmission - Rearend 2 12-24-2006 12:14 AM
Opinions on body mod ideas rusttorod Body - Exterior 2 04-20-2004 08:59 PM
