How bad is this? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2004, 05:14 PM
I dun learned sumthin
How bad is this?
A while ago I had a poly lock back off on one of my exhaust valves. Ever since this happened I have not been able to make it stop backfiring through the carb. I figured that i didn't have the timing down right. Any way it developed a leak at the back of the intake manifold. I went to pull off the manifold and when i did i noticed that that lifter was way down in its bore. I thought that was strange so i pulled it out. The bottom is completely concaved in with alot of metal missing. It also ground my cam almost flat. The valve had a very slight bend in it above the guide. I guess my question is has running all of those metal shavings through the engine smoked the bearings or am I ok. Oh and by the way latley I've noticed a sporatic knocking coming from the lower end of the engine.
Old 06-12-2004, 06:12 PM
DoubleVision's Avatar
It`s likely the bent valve caused it to not open, thus wearing the cam lobe out and killing the lifter. It`s a good chance bearing damage occured, the only way to know is to pull the pan and check the bearins. I would go ahead and yank the whole thing and do a rebuild, if the valve stuck open at any point there`s a chance also it burned the valve.
Old 06-12-2004, 08:43 PM
NorthStar's Avatar
Re: How bad is this?
[i] I went to pull off the manifold and when i did i noticed that that lifter was way down in its bore. I thought that was strange so i pulled it out. The bottom is completely concaved in with alot of metal missing. It also ground my cam almost flat. The valve had a very slight bend in it above the guide. I guess my question is has running all of those metal shavings through the engine smoked the bearings or am I ok. Oh and by the way latley I've noticed a sporatic knocking coming from the lower end of the engine.
I think you answered your own question.
Its gotta come apart.
