How bad can a torque convertor ring gear be (SEE PICS) - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2008, 11:33 AM
I'm putting a trans on a motor and the ring gear is worn in spots. How bad can it be worn before it will cause any real headache? Will the starter still engage if the ring gear is like this?
Old 04-04-2008, 12:36 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I am not seeing any photos , links or thumb nails of larger photos
Generally worn or missing teeth on a ring gear indicate a need for replacement.
Old 04-04-2008, 07:19 PM
Sorry my pictures didn't show up, my @^*^#!!*(&$#@^$#@ computer is a !@#$%^%$#$@! piece of %$#@!$^&*&^%$ . AAAAHHHH!!!!!!! I'll try them another time.
Building a SBC to rev to 8k, and have power Andyrew Engine 52 04-17-2006 12:46 PM
Torque Convertor, is it going bad or is it something else? August Transmission - Rearend 4 10-02-2003 02:49 PM
bad headgasket as suspected.. pics inside... Gino Fultano Engine 2 09-03-2003 06:56 AM
T-10 gear gone bad cafloh Transmission - Rearend 1 10-23-2002 05:14 PM
9" Ford (Bad gear set from Summit?) mcbroom Transmission - Rearend 4 02-07-2002 03:23 PM
