LinkBack | Thread Tools |
For the bars to meet at the center of gravity, you will need to have the front of the lower bar higher than the rear. Visualize the intercept of the lines to land somewhere around the back of the engine/bellhousing area slightly above the crankshaft. Its always a good idea to add some adjustability though.
Thanks for the replies.
I was under the impression that the lower bar being parallel to the ground and the two bars (if extended) intersecting at the COG were two separate guidelines. However, I suspected what you are saying was correct because in many cases the two guidelines are mutually exclusive. Thanks for the way-back link, I had seen a link to that page somewhere before, but the link was broken. I forgot the wayback machine even existed.Even with the lower bar at a 12 degree angle (lower in back), if I install the upper triangulated bars at a 6 degree angle (on the vertical plane -- 40 degrees on the horizontal plane), they will meet very very close to the COG. Is this all I need to do? |
| leaf springs or 4 bar suspension? Is a 4 bar worth the expense? | Hemi-Meadowbrook | Suspension - Brakes - Steering | 7 | 03-09-2011 07:18 AM |
| '55 Chevy Swap to 4 Bar Parallel Suspension | Merton Beebe | Suspension - Brakes - Steering | 19 | 11-18-2007 07:46 PM |
| Help Rear suspension Parallel Four-Link | ChevyLuvTruck | Suspension - Brakes - Steering | 13 | 08-12-2007 06:27 PM |
| Parallel Leaf Front Suspension | scrimshaw | Suspension - Brakes - Steering | 10 | 02-22-2007 09:23 AM |
| parallel leafs, or ladder bars & coil-overs? | sandman351 | Suspension - Brakes - Steering | 1 | 08-28-2004 08:33 AM |
