How Big - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2008, 09:24 PM
Hustles365's Avatar
How Big
I have this 400 sbc how big can I build this motor and still drive it on the street spending only 2500.00
Old 05-25-2008, 12:23 AM
Well... since you say
I say dig deeper and try something like this on your bored block using your reground crank. Digging deeper will make you smile big, and something this will be plenty BIG enough for you... IMO
Scat, 4340 Forged I-Beam Rods, Chev SB (LJ), 5.700", Bushed w/ARP 8740 Capscrews
Item :SCR5A
Price : $229.95
Clevite 77, Rod & Main Bearing Kit, Chev SB LJ, 400 Main Rods: .010", Mains: .010"
Item :1038K1010
Price : $58.95
Keith Black, Hypereutectic Pistons, Chev 400, 4.155" Bore 3.750" Stroke, 5.700" Rod
Item :KB12530
Price : $242.99
Hastings, Moly Ring Set, Pre-Gapped, 4.155" Bore 5/64, 5/64, 3/16
Item :2M66130
Price : $59.99
Dart, Pro-1 Aluminum Chev SB Head, 215cc/64cc, Assembled
Item :11510020KA
Price : $1,129.95
Elgin, Hyd. Flat Tappet Complete Cam Kit, Chev SB, .447/.447 290/290, 223/223, 114 LC
Item :E903K
Price : $129.95
Melling, Standard Volume Oil Pump, Chev BB 396-454
Item :M77
Price : $27.99
Moroso, Hardened Oil Pump Shaft, Chev SB w/BB Pump
Item :22090
Price : $15.99
S.A. Gear, Billet Steel Double Roller Timing Set, Chev SB
Item :78500T
Price : $69.99
Professional Products, CrossWind Dual Plane Intake, Chev SB
Item :52026
Price : $157.95
Holley, Street Avenger Carburetor, 770 cfm, Electric Choke
Item :0-80770
Price : $399.95
SCE, Accu-Seal Pro Complete Gasket Set, Chev 400
Item :211400
Price : $101.99
Subtotal: $2,625.64
Old 05-25-2008, 12:34 AM
techinspector1's Avatar
Wiki Edits: 326
The limit on a 400 with standard deck block (9.025") is 434 cubic inches. (bored 0.030" with 4.000" crank).
http://www.speedomotive.com/ps-536-8...roker-kit.aspx
Add the items Stroke mentioned, plus the machine work, plus all the nit-pick stuff that you never budget for.
big chevy monster hp Ratoflic Engine 5 12-07-2005 10:06 PM
Is my Torque Converter too big for my setup ?? 74NovaRat Engine 15 02-01-2005 09:23 AM
Big cars Wmarden Hotrodders' Lounge 16 09-12-2004 09:05 AM
Big Mack Kevin45 Hotrodders' Lounge 0 12-08-2002 01:33 PM
big tires? cannedheat Body - Exterior 6 10-16-2002 01:35 AM
